Ford to replace spark plugs with lasers
Old Jul 17, 2009 | 02:45 PM
zoom44's Avatar
Ford Motor Co. and researchers at the University of Liverpool are developing a car ignition system that swaps spark plugs for a laser beam to start vehicles while generating fewer greenhouse gas emissions.
The team has just received nearly £200,000 (US$320,000) in grants to test the technology from the Carbon Trust, a government funded entity charged with helping businesses in the transition to a low carbon economy. The award is part of the Carbon Trust’s Applied Research grant that supports the development of low carbon technologies.
Ford reportedly plans to install the laser ignitions in a select range of vehicles in the next few years before expanding the laser ignitions on a larger scale. The technology works like this: The laser is quickly directed toward the combustion chamber where the fuel is most concentrated, allowing the engine to run on a more efficient mix of fuel and air. Bigger diameter valves that improve engine gas flow could be used in such a system because the thin fiber optic cable delivering the laser beam is smaller than a spark plug. The laser is also more reliable than a traditional spark plug.
The laser ignition may also overcome a significant barrier to widespread adoption of biofuels -- starting the vehicle when the engine is cold. According to the Telegraph, reflecting part of the laser back from inside the cylinder can deliver information on fuel type and ignition level to allow vehicles to optimally adjust the air/fuel mix.
“Laser ignition is a really exciting technology because it improves the efficiency of petrol cars and could, in the future, speed the uptake of cars run on biofuels derived from sustainable organic materials such as algae,” Mark Williamson, the Carbon Trust’s director of innovations, said in a statement.
other articles talk about using multiple beams to ignite the fuel at separate points in the chamber. they are expected to start using them in some cars by 2011.
Old Jul 19, 2009 | 03:25 AM
m477's Avatar
rotary courage
So does the engine make those laser beam sounds like from cartoons? PEW PEW PEW!
Old Jul 19, 2009 | 06:21 AM
kvndoom's Avatar
The Slow and the Serious
Shoop da Whoop!!!
Old Jul 19, 2009 | 07:10 AM
tjbourgoyne's Avatar
tjb
Lasers are the most ineffcient invention of all time but in this application it only has to travel a short distance. Seems like it would be ideal for diesel engines, ditching the glow plugs.
Off topic, but Mitsubishi has a laser TV out, very expensive but the picture never fades and it uses less energy. They are also developing projectors meaning the bulb never needs replacing and the picture is better.
Old Jul 23, 2009 | 07:09 PM
Lasers are used in dental work and eye surgey
Old Jul 23, 2009 | 09:33 PM
8 Maniac's Avatar
Senior Member
how does it compare to the LED TV's that samsung is using? Those are supposed ot use less energy as well... plus their thin.
tiltmode43's Avatar
OMGITM!
Old Jul 23, 2009 | 09:50 PM
Easy_E1's Avatar
Repost! Not really but the same subject.
https://www.rx8club.com/general-automotive-49/laser-ignition-no-more-spark-plugs-178914/
Old Jul 23, 2009 | 09:51 PM
tiltmode43's Avatar
OMGITM!
The other thread is the repost, lol...
Old Jul 24, 2009 | 08:17 AM
alfy28's Avatar
that is pretty cool.
Old Jul 24, 2009 | 08:35 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
"All I freakin' asked for is a Ford Focus with freakin' laser beams to start the engine!"
Interesting non-the less. Nothing like a period or soaring fuel costs and a green movement. I mean, think about it, the 90s big engine change was variable valve timing (it seemed) and traction control+stability control on top end cars.
Now, we've got direct injection, hybrid drives, fully plug in electric production cars, hydrogen car prototypes. It seems like there have been way more advancements in the last 10 years than the ten years before that. Just an opinion.
Old Jul 24, 2009 | 09:59 AM
dillsrotary's Avatar
jersey fresh
I'm interested on the type of laser used. If the fuel ignited with the center of the chamber (or by the highest concentration) or does the laser reflect off the cylinder walls and those points are the ignition points. Is it a single beam or multiple?
Old Jul 24, 2009 | 10:05 AM
ATL-GP's Avatar
Speed is all you FN NEED
OMG!!!...this sounds REAL RELIABLE...and uuuuuhh...how much is a tune up on a Mustang GT now..Imagine if they put this in there. I'm all about innovation, but as broke as folks are now, make that **** LAST!!!!!
Old Jul 24, 2009 | 10:33 AM
Flashwing's Avatar
3-wheeler
It sounds to me like the laser would have the ability to alter its firing angle to target the largest concentration of fuel. Since fuel atomization isn't an exact science this certainly would lead to increases in miles per gallon since the largest fuel areas would be combusted every time.
The notion of being able to use laser feedback to determine air/fuel ratio would also be a vast improvement. O2 sensors have some delay in them while you would be dealing with the speed of light. The latency for something like this would be so small that combined with a high powered computer it could make thousands of adjustments every second if necessary.
Being able to run leaner mixtures at a higher compression is technology that is already available and is capable of producing high powered cars that get loads of fuel mileage. The problem is this technology isn't compatible with our current emissions technology aka the catalytic converter.
This is certainly more promising than the bogus plan of forcing people into smaller cars.
Old Jul 24, 2009 | 11:10 AM
jersey fresh
This sounds interesting, dealing with a 3 dimensional space I wonder if the laser will combust the fuel "mid flight" or need the cylinder walls as a target?
Direct injection fuel usually follows a path such as this:
So you could have a preexisting "assumption" as to where the largest fuel density will be. I'm just curious to how they'll pin point such a location on a moving atomized fluid.
Old Jul 24, 2009 | 01:04 PM
rotarygod's Avatar
Just put the ignition back where Felix Wankel originally had it. On the rotor faces themselves. This assumes that the lazers would never need replacing like a spark plug does. That's the perfect spot as the air/fuel mixture is always in contact with the point of ignition rather than having to be lit as it flies past it.
Old Jul 24, 2009 | 01:17 PM
exsequor's Avatar
wipe me down
How are lasers inefficient?
Old Jul 24, 2009 | 01:33 PM
Im_DANomite's Avatar
I love GOOOLD
Originally Posted by Vyndictive
this is all i can think about when i see the word 'laser'
"throw me a fricken bone here!"
Old Jul 29, 2009 | 01:08 PM
tjb
I remember my physics teacher in college telling us this fact. It has to do with expending a lot of energy to have an effect on a single point.
Old Jul 29, 2009 | 01:25 PM
lone_wolf025's Avatar
Future Rotary User
I don't foresee this actually happening. The cost of these laser ignition systems as compared to traditional ignition systems would be staggering I imagine. And for how much gain in efficiency?
Old Jul 29, 2009 | 01:34 PM
zoom44's Avatar
20%
Old Jul 30, 2009 | 03:18 PM
thawk97's Avatar
...pondering...
very interesting - with the way the plugs get fouled, I wonder how they plan to keep the laser lens clean from carbon and fuel residue etc. Seems like if carbon did happen to get on there the heat of the laser would just bake it onto the lens rendering the "plug" useless - if the light can't get into the chamber, it won't work so good....and I can imagine replacing a laser head would be a little more expensive than a standard plug.
ironj221
36
Jan 20, 2026 08:28 PM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
PotatoCannon
Sep 6, 2015 11:48 AM
Belalnabi
Jul 17, 2015 07:48 PM
