KHANVICT
07-16-2009, 10:36 PM
im looking if anybody did a mod that your front indicator bulbs are always on, and when you turn they blink
sorta like this
http://www.youtube.com/watch?v=KmUsiKqIC5Q&feature=related
Spinning Sushi
07-16-2009, 10:41 PM
PM Rotary Rasp, he makes them. :)
Aipex8
07-17-2009, 01:05 AM
You need to have a dual filiment bulb to do this. One that doubles as parking light and signal. For the 04-08 models, the signal is a 7440 (single filiment) bulb. The 7443 (dual filiment) bulb is the same size, so I suppose you could find source a couple of sockets (I would suggest from the tail/brake harness which is also a 7443) and modify them to fit, then tap into the existing parking lights power for the third wire on the new harness.
If you have an 09, just get the switchback bulbs and plug in as they already use a dual filiment bulb.
If you want to do the side marker you are probably looking at a custom build as none of the larger premade switchback LEDs will fit in them.
KHANVICT
07-21-2009, 12:21 PM
thanks alot aipex8 ,
does anyone have any pics of an 8 with white signals that are always on??
