Misfires at highway speeds when decelerating?
Drive it like u stole it!
for the past 4 months i have noticed that my car sometimes misfires on the highway. recently i noticed it was only when i let off the gas at highway speeds.it now happens every time i let off the gas for more then a couple seconds, but stops soon after i begin to press the gas again. i have replaced the spark plugs, coils, and wires and the promblem still exist. i also removed my cat thinking that might be it but i still get misfires. this all started happening after my car was at mazda for 3 weeks getting the transmission rebuilt. do you think that it may be a clogged/dirty fuel pump or injector from sitting so long? i run shell 93 most of the time and have only used premix about 4 to 5 times. i havent really noticed any loss in power. i have a 2005 mt with 53k miles. thanks for your input. hopefully i gave enough info bc i have limited internet access right now. but i will be online a couple times a day.
i get a flashing cel when decelerating and after a couple times it stays on (but still flashes during misfire). check the codes and have a cylinder(rotor) 1 misfire and multiple cylinder(rotor) misfires.
so fuel cuts off completely? maybe i have a bad sensor or something. do you know what sensor senses misfires?
no...i havent noticed any power loss.....i can still bark 3rd gear......around the city i get no misfires at all only when im on the highway for more then like a min......its really strange...
DESCRIPTION
Some vehicles may experience the following symptoms.
- On manual transmission vehicles, when decelerating in 3rd gear with engine speed less than 3,000 RPM at
approximately 30 MPH (50km/h), then quickly depressing the accelerator pedal again, a hesitation may
occur. This symptom can only be observed in this engine speed and vehicle speed range.
- On automatic transmission vehicles, when at a stop in D range, excessive engine/body vibration may occur.
This body vibration does not occur in P or N range.
http://www.finishlineperformance.com...01-09-2062.pdf
car, decelerate, decelerating, engine, gas, highway, intake, letting, manual, misfire, misfires, misfiring, speed, speeds, transmission
