Sound!!
Old Jul 16, 2009 | 12:19 AM
Ka_RX-8's Avatar
CA Sound!!
HI guys.. i got a 04 MT GT...i've been heard my weird sound recently
if i press brake pedal when my car is completely stop,i will hear some like air pump sound....
and when my car's engine is on,i hear some water flow sound all the time, are those normal??
Old Jul 16, 2009 | 12:25 AM
DriftX8's Avatar
strange.. i wouldnt worry about it too much if your engine lights not on or anything. the air pump sound is normal but i cant explain the water flow noise. pop open the hood and make sure all the caps are on and tight but if your sketched take it to the dealer, or pepboys if you dont care about your car
2008 Special Edition 40th Anniversary RX-8 - Greddy SE Catback Exhaust - K&N 69-Series Typhoon Short Ram Intake - COBB AccessPORT ECU Programmer - Bilstein Shocks, exclusively designed for this limited edition RX-8 - Urethane Foam filled Suspension Cross Member - P225/45R18 Tires - APR GTC-200 Carbon Fiber Spoiler / MazdaSpeed Spoiler - 18 in" Aluminum Alloy Rims, Flat Black - Black and Purple painted Emblems - Purple painted Calipers Mmm, purps!
Old Jul 16, 2009 | 12:50 AM
wow,
the info is vauge at best, and not much at most..
when you press the brake pedal at a stop and you hear an air pump.. and then you start the motor?
i would start with the owners manual.. lots of helpful hints in it.
might look at the abs test section..
as to h2o flow. you might have some air in the heater system. but you might not.
Old Jul 16, 2009 | 02:46 AM
Ka_RX-8's Avatar
and those are two diff questions ..sorry..=.=..
1: if i press the break pedal,when the car is completely stop i can hear some air pump sound..
2: when my engine is on, i hear water flow sound all the time....
and i do care about the car......
okay i will look at the abs test section..
yea engine is not on ..runs fine and everything...
i am just worry....~~
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
