Clutch Barely engages after cluth pedal adjustment
Old Jul 13, 2009 | 11:05 AM
WVBoosted8's Avatar
hey guys, I have been fighting with my clutch on and off for 6 months now. My stock one went out so i had a shop install a exedy clutch and prolite flywheel. After a short period of driving I noticed it was increasingly harder to get into reverse. Then all the gears were all hard to get into. I took someones advice on here to adjust the clutch pedal. I fine tuned it until I was happy with how it engaged.
Fast forward a couple of months and today it is worse than ever out of nowhere. It appears that the adjustment hasn't moved and it is almost as high as it will go. At the time of install, he also installed a SS clutch line. I am leaning toward thinking it was a problem with the install itself but wanted to see some other peoples opinions.
Old Jul 13, 2009 | 02:04 PM
Race Roots's Avatar
Former Sponsor
Have you checked the clutch pedal assembly? It could also be the slave cylinder as well.
Old Jul 13, 2009 | 02:06 PM
dozer's Avatar
on his 3rd rx8
make sure you bracket didnt break, this happened to me outta nowhere, it started feeling like the gears were harder to get into the reverse was a bitch...
Old Jul 13, 2009 | 02:17 PM
dozer's Avatar
on his 3rd rx8
does the pedal feel loose? does the engagement point seem like its getting smaller?
heres what a broken bracket looks like
https://www.rx8club.com/series-i-trouble-shooting-95/dozer-needs-help-cluth-feeling-loose-177531/
Old Jul 13, 2009 | 03:25 PM
Jon316G's Avatar
Grasshopper
Agree to check the pedal play.
After I did a clutch/flywheel install, my engagement point was almost instant.
As soon as I lifted my foot off the clutch pedal, it would engage completely (and stall the car if I didn't keep it going).
Adjusting the pedal play alone wasn't enough for me.
I actually had to adjust the pedal stroke then adjust the pedal play.
This was after realizing my pedal stroke was 1/2" less than the OEM requirements.
After adjusting my pedal stoke from 4.5" to 5" and then adjusting my pedal play, it feels like it always did before the install.
And like Dozer mentioned, also check the bracket to see if its cracked.
Now that you have an upgraded clutch, you're more prone to clutch bracket failure.
Old Jul 13, 2009 | 08:22 PM
WVBoosted8's Avatar
I will have to check it out on wednesday, thanks for all your help guys.
Old Jul 13, 2009 | 08:25 PM
dozer's Avatar
on his 3rd rx8
dont forget to report back
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
