Check engine light!!!!help!!!
Old Jul 12, 2009 | 07:57 PM
Hwy9RX8's Avatar
Fly High.... or FALL FAST
well im not sure which owner i am probably 2nd or 3rd bought it from the dealership when it was around 48xxx, been keeping up with tuneup other than sparks and coolant. all reacalls have been serviced
drove my car on Friday after a long time of it just sitting... (i probably drove it for only 4 days the past month.. ) i was running out of gas so i got some and after that stop by a store will quick to take a **** and when i came out it couldn't start i popped the hood to look around. went back inside and it started... after that went somewhere again chilled for like 30 min and it couldn't start again i waited a few min and it was able to start... the following day i got rough idles motor vibrations and a check engine light....
so far i changed battery(needed a new one anyways)
did oil, check MAF, check alternator,cleaned fuel system, check coil wires, did a battery reset and currently trying to check spark plugs i just need the socket.
i doubt that its a blown apex seal or anything wrong with the engine itself. seems more electrical.... if not that than watered down gas? in which ive already used fuel cleaner to at least neutralize the situation. no difference...
yeah i have been doing research online for the past two days. i was thinking about just getting it diagnosed Monday, but when i drove it around the neighborhood it dies sometimes and i have to put it in gear to start it again....
not sure if it can make it to the shop...
Old Jul 12, 2009 | 09:01 PM
Juice's Avatar
I made some poos
If you have a CEL, the only way to know what could be causing it for sure is to get the code read.
Come back when you have a code and we can help further diagnose the problem. Throwing parts at it isn't going to help.
You can get the code read at an auto parts store usually for free. Or you can find a local member who has a code reader to read it for you.
Old Jul 12, 2009 | 09:23 PM
Jon316G's Avatar
Grasshopper
So you've gone over 48k miles without changing the plugs?
You likely have a misfire code and might require changing plugs.
But get the code read just to be sure. Autozone will do it for free.
Old Jul 12, 2009 | 09:42 PM
I8U's Avatar
I8U
Have the code read as said before...
Old Jul 12, 2009 | 10:04 PM
05rx8mazda's Avatar
B.I.G
yeah bro is the check engine light flashing or is it just on???? also check your plugs a sockets costs like 4-6 bucks at autozonbe depending on what kind you get. th plugs can get expensive though. Order them through a vendor here an they are a much better price.
Old Jul 12, 2009 | 11:11 PM
or just get your plugs thru Amazon. they probably have the best price
if your car has all TSB/recalls up to date then its probably not it ... it could be a dead engine.
check the cel first.
Old Jul 13, 2009 | 10:49 PM
Hwy9RX8's Avatar
alright guys just finished getting a scanner and it came out p0301 misfire in the first cylinder in our case the first rotor... so i guess from here im going to check the spark plugs as soon as i get a breaker bar.....
then from there ill check
Faulty oxygen sensor(s)
Faulty fuel injector
Faulty catalytic converter
i hope this is just the plugs.......
Old Jul 13, 2009 | 10:53 PM
Jon316G's Avatar
Grasshopper
A breaker bar for your spark plugs
Better make sure to put anti-seize on the new plugs.
then from there ill check...
Burned exhaust valve
Exhaust valve?
Let me know how that one goes
Old Jul 13, 2009 | 10:54 PM
Hwy9RX8's Avatar
oh yeah haha damn now i feel stupid freaking valves.... gotta take that off
Old Jul 13, 2009 | 10:58 PM
Jon316G's Avatar
Grasshopper
LOL let us know how the new plugs work out for you.
Remember to clear the CEL after you install the plugs too.
Old Jul 13, 2009 | 11:01 PM
Hwy9RX8's Avatar
of course probably do it tomorrow
Old Jul 19, 2009 | 09:44 PM
Hwy9RX8's Avatar
allriiight recently replaced plugs because they were worn out anyways but now i have another code which is p0506
so after searching information and figuring out what it ment basically opened another list of stuff....
A P0506 DTC trouble code may be caused by one or more of the following:
A vacuum leak
An air restriction in the intake air path or exhuast
A faulty positive crankcase ventilation (PCV) valve
Damaged/failed/dirty throttle body
Internal engine problem (I HOPE ITS NOT THIS)
Failed PCM
so i guess im going to check the vaccum leaks right now anyone have any suggestions on which one's to check at what location?
Old Aug 19, 2009 | 02:59 PM
Hwy9RX8's Avatar
for anyone that had the same problem this is pretty much how it was fixed....
after replacing the spark plugs in which i figured out 3 of them were dead in which i was only running on one rotor...
i then tested my wires and only 1 of them worked...
i then checked my ignition coils and of course only 1 worked...
so in conclusion...
spark plugs.....$65
wires ......$150ish
ignition coils......$50 each
Keep in mind I am rounding up...
total price let just say $400
Old Aug 19, 2009 | 03:07 PM
cyclone1208's Avatar
wow where did u buy yur parts?
Coils are $30 each
Plugs are $20 each
Wires are $60-$70
U got ripped off
Old Aug 21, 2009 | 12:12 AM
Hwy9RX8's Avatar
Coils are $30 each
Plugs are $20 each
Wires are $60-$70
U got ripped off
got it at the local rotor shop other than plugs which was 65$ total for 4 and where can u find wires for 60-70?
Old Aug 21, 2009 | 06:03 AM
I8U's Avatar
I8U
With any one of the dealers here on the forum, BHR, Fluid...
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
