2nd Gear Feels Weak
Old Jul 9, 2009 | 03:58 PM
Jonathan11's Avatar
Pain Is Weakness
Question 2nd Gear Feels Weak
Okay heres my story, Ive had my car for about 7months now. Just last Month a rattle began to develop in the rear of the car @ about 1k - 1.5k. I believe its the exhaust heat shield. A week later I start hearing like a rattle noise were the tranny is, again im thinking its a ehat shield or some type of shiled thats loose. So the week following that I began to notice the car feel kind of slugish in 2nd gear. Im not having any problems shifting up or down, and i just keep feeling like 2nd gear is slipping or something. I havent seen any post with a similar problem like mines, so any input will be great. O and before i forget i did the 30k service @ a Mazda stealership, and they did do a tranny flush and put their generic crap in it, the car has 37k miles on it now.
Old Jul 9, 2009 | 05:32 PM
Donald.Clabaugh's Avatar
what do you mean sluggish... say you are under hard accel from first to second to third.... does it seem to loose power only during second? Is there any excess noise that goes along with this problem....?
Old Jul 9, 2009 | 06:21 PM
Jon316G's Avatar
Grasshopper
Far as the rattling... it could be a heat shield.
I had rattles from the shield on my exhaust manifold.
The other issue with "slipping" in 2nd gear... you need to be more specific.
Does it feel like its slipping like when the clutch disc doesn't engaged against the flywheel?
Does the car have a "power loss" in 2nd gear? And if so what RPM?
Definitely need more details.
Old Jul 9, 2009 | 08:22 PM
Jonathan11's Avatar
Pain Is Weakness
Okay, it feels like the car is accelerating too slow, lack of power. And you can feel that its not the engine. The power loss is thru out all rpms while in 2nd. 3rd and 1st gear seem to be way more responsive.It just feels like its lost its punch in 2nd gear. If I take it 2 red in 1st n drop it in 2nd the clutch does not slip or anything it grabs n the rear wheels cherp, so I don't belive its a clutch issue. No noises out of the ordinary. Just a feel of pwr loss.
Old Jul 9, 2009 | 08:39 PM
Jon316G's Avatar
Grasshopper
Basic things to check for power loss is coils, plug wires, spark plugs, and clogged cat.
Have you replaced any of these?
Old Jul 9, 2009 | 08:58 PM
wouldn't those have an effect through out several gears? do you think it has anything to do with 2nd gear itself...? Idk jon I could be way off.
Old Jul 9, 2009 | 09:19 PM
Jon316G's Avatar
Grasshopper
His problem may not be gear specific... it might just be that he notices it more in 2nd.
If a gear fails or is failing, the symptoms would be different.
Old Jul 9, 2009 | 09:49 PM
I guess we wait to see whats been done then.
Old Jul 10, 2009 | 09:23 PM
Jonathan11's Avatar
Pain Is Weakness
Okay I have replaced the starter, I did the BHR ignition upgrade, cleaned throttle body, did throttle body by-pass mod, and removed the little plastic plates in the stock air box. I use 10w30 oil, top off every 500 n premix every fuel up. I rly don't think its an engine problem, u can feel like the engine is kinda freesping as if the tranny is not putting the power down. I've been reading up, I read our cars do. 0-60 in about 6seconds. I was thinking about timing my 0-60 and seeing if I get the same time. If I do no problem all just in my head. If I don't.....problem.
Old Jul 10, 2009 | 10:58 PM
Jon316G's Avatar
Grasshopper
Did you replace the plugs also when you installed the BHR coils?
Have you double-checked to make sure a wire hasn't come loose on the plug?
Old Jul 12, 2009 | 12:50 PM
Jonathan11's Avatar
Pain Is Weakness
Yea everything is in prefect working order. Timed my 0-60 today did 3 runs, from complete stop to 60. My average time was 6.4 seconds. That being said you think thats an accurate way to determine if my tranny is bad? I mean if there was something wrong with second gear I would not be able to do 0-60 in under 7 seconds right?
Old Jul 12, 2009 | 02:36 PM
Jon316G's Avatar
Grasshopper
6.4 sec is pretty good.
You need to know the right shift points, and like you said be able to shift, to get a time like that.
Old Jul 12, 2009 | 03:04 PM
AE92's Avatar
did you notice the traction light go on right after you chirp into 2nd? cuz if i dump the clutch too fast after redlining first and hitting second, my traction light goes on and i lose power for a little bit then 2nd gets it back.
Old Jul 12, 2009 | 11:01 PM
05rx8mazda's Avatar
B.I.G
+1^^^^ yeah when i turn of the traction control the car does accelerate a bit quicker.. DSC makes the car retarded
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
juicemantwon
Sep 26, 2015 12:30 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
