Car wont start (rapid ticking). Dying battery?
Old Jul 3, 2009 | 04:14 PM
turborx8's Avatar
Boost 4 Life
ON Car wont start (rapid ticking). Dying battery?
I did not leave any lights on overnight and drove the car yesterday with no problems.
I tried to start it today and I get a rapid "tic-tic-tic-tic" sound until I stop turning the ignition.
I am thinking it might be from a weak battery but I was able to put my headlights on no problem. I am charging it now. *fingers crossed*
Any other ideas?
Old Jul 3, 2009 | 04:19 PM
04RX8man's Avatar
Rotary Powered Countryboy
how old is your battery? That's what mine did when it went bad one day was fine next morning went out and tick tick tick.....no warning just went out!
turborx8's Avatar
Boost 4 Life
Originally Posted by invasion08
Its your starter.
Where would be the best place to order one online?
I would prefer the 2006+ upgraded starter.
Old Jul 3, 2009 | 04:22 PM
invasion08's Avatar
But first make sure that your battery is good. Are you able to jump start it?
Old Jul 3, 2009 | 04:28 PM
MazdaEight's Avatar
Had the same thing happen last week. Bought a new battery now its fine.
Old Jul 3, 2009 | 04:33 PM
invasion08's Avatar
Your battery does not have enough juice in it to turn the starter to start your car.
Old Jul 3, 2009 | 04:56 PM
EDZRIDE's Avatar
2005 White GT
Have the battery load tested before you condem the starter. Also, if you do get it running, check the charging system.
Old Jul 3, 2009 | 05:00 PM
rodjonathan's Avatar
silent assasin
mine did that a week ago changed the batter it works just fine now
Old Jul 3, 2009 | 05:03 PM
turborx8's Avatar
Boost 4 Life
Cool.. thanks guys.
At least a new battery is a quick fix.
Old Jul 3, 2009 | 05:05 PM
TheWulf's Avatar
My 8 looks like a Smurf
Had the same issue a few years ago. Problem was the battery. Bring it to CT they do a cold crank test for free.
Old Jul 3, 2009 | 10:10 PM
turborx8's Avatar
Boost 4 Life
I got the car started after charging the battery for a few hours.
I hooked up my Cobb AP and was monitoring the battery voltage @ idle and it was reading 13.9v. Then after a 20min drive I turned off the car and it was @ 11.8v.
Do those numbers seem normal?
Old Jul 3, 2009 | 10:23 PM
alnielsen's Avatar
The reason the voltage was normal while the engine was idling is because the alternator was topping off the battery. If it is at 11.8 when the car has been turned off, the battery has at least one weak cell and should be replaced.
Old Jul 3, 2009 | 11:48 PM
turborx8's Avatar
Boost 4 Life
Excellent info. Thanks bro!
marc2820
Jul 26, 2015 10:47 PM
madrotor
Jul 26, 2015 12:06 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
Belalnabi
Jul 17, 2015 07:48 PM
