WTF is a VDI solenoid valve control circuit?
Old Jul 2, 2009 | 11:04 AM
SpeedGSXR's Avatar
Hi, I'm throwing some CELs - YES I have looked at the linked CEL codes thread, which is where I got the title from. I am throwing PCM - P0076 which the thread states is a "VDI solenoid valve control circuit low OFF 2 CCM" ...but I have no idea what 'VDI' or 'CCM' means.
Can anyone tell me what those acronyms mean or what the whole message means?
Also, did anyone decide what the ultimate cause of a Rear Rotor Misfire (P0302) is?
Thanks.
Old Jul 2, 2009 | 11:20 AM
dude ... you dunno where is your VDI ?
when you get that that usually means its "stuck" and your engine is running out of breath, thats why u will see P0302.
Old Jul 2, 2009 | 01:39 PM
I8U's Avatar
I8U
Thanks.
Usually means your rear coils, wires, or plugs are toast.
Old Jul 2, 2009 | 01:53 PM
Phalkhan's Avatar
I dont know what the rest of the code means, but here is a diagram of the VDI
http://manual.rx8club.ru/esicont/en/...320130T06.html
Old Jul 2, 2009 | 03:11 PM
Jon316G's Avatar
Grasshopper
VDI = Variable Dynamic Effect Intake-Air
CCM = Comprehensive Component Monitor
You can easily verify if the VDI valve is stuck.
Here is a link to a DIY on how to check it:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-troubleshoot-intake-valves-174009/
The solenoid is trickier to reach. Its behind/under the upper intake manifold.
Old Jul 6, 2009 | 02:45 PM
SpeedGSXR's Avatar
I just replaced my plugs with brand new stock ones, and I bought the BLACK HALO RACING ignition kit (their coils, their wires), all installed correctly.
I'm starting to hate this car, it never seems to run right and I take better care of it than my turbocharged S2000 DD...
Old Jul 6, 2009 | 04:00 PM
Did u bought the car brand new ?
Old Jul 6, 2009 | 05:29 PM
I8U's Avatar
I8U
Did you reset the PCM properly? ie the 20 brake pedal stomp procedure? If you're still getting a misfire code it could be the PCM itself. My car had misfire codes like crazy, we swapped out everything piece by piece and finally swapped out the PCM and finally got it fixed.
WranglerFan
Nov 5, 2017 09:35 AM
Evan Gray
Nov 24, 2015 01:00 AM
pjwermuth
Sep 28, 2015 11:36 PM
