Front Bumper Removal
Old Jul 1, 2009 | 12:02 AM
MrAdam5's Avatar
So I decided to put grilles on the front bumper. Just in the bottom center and over the oil coolers (they were taking a beating). The instructions that came with the grilles were fine for taking off the basic bumper, but when it came to the part about fog lights and headlight cleaners it has no explanation on how to remove them to be able to separate the bumper from the car. I looked around a bit but didn't have much luck finding out how.
Does anyone know how you're suppose to take off the fog lights and headlight cleaners from the bumper properly? I think I spotted about 4 screws (for each side) that would let both parts come completely off the bumper. Is that right? Those'll be a pain to get back on later that way...
Old Jul 1, 2009 | 12:07 AM
Jon316G's Avatar
Grasshopper
For the fog lights, there is a wire harness for each light that you disconnect.
The fog lights stay on the bumper.
We don't have the headlight cleaner here in the US, but I assume it too has a harness that needs to be disconnected (and probably a hose for the fluid).
Old Jul 1, 2009 | 12:16 AM
Jon316G's Avatar
Grasshopper
Straight from the shop manual:
Looks like there is a joint connection for the headlight washer on the sides of the bumper.
Old Jul 1, 2009 | 12:26 AM
MrAdam5's Avatar
Thanks, that diagram helped for the washers. I didn't quite know where I should have been making the separation. Those fog lights though, I could find the connector just no way of actually taking it off unless I forced it. It'll have to wait for tomorrow now though, its dark out! Thanks for the fast reply!
Old Jul 1, 2009 | 12:45 AM
I thought the fogs were a bitch. I think the tab is on the inside. push in to release.
The tab is only on one side.
There is something in the DIY section but it will be a search.
Old Jul 1, 2009 | 06:23 PM
MrAdam5's Avatar
Whew, finally managed to get it. Those fogs were stuck on there good! Anyway, thanks for the help.
Old Jul 1, 2009 | 07:00 PM
2tone's Avatar
The RX-8 is missed
good ^^
if i recall correctly the fogs TWIST and then pull out/back. it is a HUGE pita to get them to twist though...
Old Jul 1, 2009 | 07:17 PM
Jon316G's Avatar
Grasshopper
I guess I still don't see the issue with just leaving the fog lights on the bumper and disconnecting the wire harness
Everytime I pull my bumper off, that's all I do.
Once I remove all the fasteners and bolts, I pull the whole bumper out slightly (since the wires for the fog lights aren't that long) and reach down and disconnect them.
But to each their own. Whatever works for you.
Old Jul 1, 2009 | 07:30 PM
MrAdam5's Avatar
Thats all I ended up doing once I could see what was going on, but the clips were still really stuck on there. Hopefully next time I have to take the bumper off they wont be so stiff.
LMURailsplitter02
Sep 6, 2015 10:56 PM
rxwilly8
Sep 2, 2015 02:42 PM
Jazzmeson
Aug 30, 2015 02:42 AM
