Is this normal?
Old Jun 24, 2009 | 11:56 PM
dcperilli's Avatar
Is this normal?
When I turn the car to start the car, sometimes it takes a little longer to turn over...is this normal?
Old Jun 25, 2009 | 12:03 AM
Spinning Sushi's Avatar
I <3 Sushi
We can not answer your question with the lack of critical information.
Year?
Transmission?
Mileage?
Old Jun 25, 2009 | 12:04 AM
shazy's Avatar
More Info PEE EL ZEE!
Old Jun 25, 2009 | 12:13 AM
I <3 Sushi
I'm gonna let you in a little secret...
The 04 and 05 have weak starters, the 06 and newer have stronger starters. There is a TSB for the 04/05.
Here's a bonus, there's also a little link on the top right of this forum labeled "Search" with an arrow pointing down.
Old Jun 25, 2009 | 12:25 AM
dcperilli's Avatar
2005 27,000 miles auto trans
if it has the weaker starter, what do you suggest I do?
Old Jun 25, 2009 | 12:26 AM
I <3 Sushi
Of course, that's only if you're still in warranty.
Old Jun 25, 2009 | 12:51 AM
05rx8mazda's Avatar
B.I.G
go to the dealership and say it takes long to crank. maybe your starter is going bad?? they should repair it man. mine did the same thing
Old Jun 25, 2009 | 09:32 AM
Nubo's Avatar
Lubricious
Yes, it can take a bit longer if the engine is hot.
Make sure you have all the flash updates.
Lots of people have good results with the improved starter.
I have 2004 with original starter and never swapped it because I find all that I've needed is a robust battery. I don't worry too much if it takes 2 or 3 seconds, as long as it starts. Usually it's much quicker than that. If it is taking more than 4-5 seconds on a frequent basis, then I'd start to worry, imho.
RevMeHarder
Jun 1, 2026 02:30 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
