Drivers Door Stuck!!!!
Old Jun 23, 2009 | 08:15 PM
Sisco360's Avatar
Exclamation Drivers Door Stuck!!!!
Today I went golfing, closed the door as normal and it was fine. I came back and the drivers door would not open!
The door lock works fine. Opens and closes. But when I pull on the handle from the inside or outside it seems like it is still locked and there is no resistance like it is jammed or something!
Any suggestions to why the handles are not unlatching the door, but button inside is saying its unlocked??
Old Jun 24, 2009 | 10:36 AM
I8U's Avatar
I8U
Maybe the linkage broke? I don't use my doors anyways, I jump the open window...hehe.
Old Jun 24, 2009 | 05:05 PM
EDZRIDE's Avatar
2005 White GT
You have a problem with the latch mechanism.
Old Jun 24, 2009 | 08:16 PM
Sisco360's Avatar
I figured it was the door latch. The linkage looks fine. I removed the handle cover and there is still tension to it. However any suggestions on getting to it? The only think I can think of is taking off the quater panel and removing the door. Otherwise, since the door won't open, I can't remove the door panel or can I??...
Any more suggestions would be awesome!
Old Jun 25, 2009 | 10:22 AM
EDZRIDE's Avatar
2005 White GT
Start here: http://www.myrotarycar.com/portal/fo...3le/index.html
Jst4fun
Apr 17, 2021 07:43 AM
vapor2
May 4, 2020 03:53 AM
TeslaMSI
Dec 10, 2015 01:10 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
