TPMS question !
Old Jun 22, 2009 | 03:12 PM
ballistc's Avatar
TPMS question !
do they last a life time or do they have some sort of internal battery?
Old Jun 22, 2009 | 03:27 PM
expo1's Avatar
He's as bad as Can
My 8 was built 5/2003 and the TPMS still work. There is a battery, but the power is only on when the car is moving.
Old Jun 22, 2009 | 03:30 PM
ballistc's Avatar
so basically as long as the car moves it last forever basically?
Old Jun 22, 2009 | 03:32 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
No, when the batteries die......................you will have to get a new TPMS. First you have to figure out which one went bad, then replace it.
Old Jun 22, 2009 | 03:35 PM
ballistc's Avatar
oh ok, a worker from big O tires said most new tpms dont have batteries and last a life time... i bought some used 2005 tpms, how long do these things last for rx8s?
Old Jun 22, 2009 | 03:39 PM
Mazurfer's Avatar
???????? I'm still on the original and I have a 2005.
Expo1 says he's had his since 2003.
expo1's Avatar
He's as bad as Can
To put it another way, while my TPMS are old, they only have about 70,000 miles on them. Do you know how many miles is on them? If yours are not installed I would put new batteries in them just incase.
Old Jun 22, 2009 | 03:45 PM
Mazurfer's Avatar
Expo1.......you sure these aren't emitting a small radio frequency all the time? How else would they do it by a centrifugal switch inside the unit?
Old Jun 22, 2009 | 03:49 PM
ballistc's Avatar
im looking at my tpms and im pretty sure they're sealed... so idk how i would replace the battery.. is there any way to check? cause i dont wana pay 80$ to get them on my car then find out they're dead..
Old Jun 22, 2009 | 03:51 PM
expo1's Avatar
He's as bad as Can
Yes, a centrifugal switch. A member tried placing 4 TPMS in a PVC sealing it and bringing the psi to 32. They didn't turn on and the TPMS light came on. That would indicate the sensors only 'turn on' when moving.
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/attempt-making-tpms-fooler-80447/
Old Jun 22, 2009 | 08:54 PM
Mazurfer's Avatar
https://www.rx8club.com/showthread.php?t=80447
wow.....MythBusters in action! How did I miss that thread.
Old Jun 22, 2009 | 08:56 PM
invasion08's Avatar
They last around 10yr 100k. Could last longer and could die sooner.
Old Jun 22, 2009 | 08:59 PM
Mazurfer's Avatar
Well that certainly narrows it down! J/K
Old Jun 22, 2009 | 09:20 PM
ferg's Avatar
yeah
Old Jun 23, 2009 | 05:35 PM
Mazurfer's Avatar
C'mon.......... TPMS = Tire Pressure Monitoring System(don't you have a manual?). If not get one for free after registering at mazdausa.com and read it.
Anyway..............it senses your tire pressure and alerts you when it falls below roughly 26psi. It actually will detect and overfill at about 49-50psi(If I recall correctly).
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Austin22
Sep 23, 2015 04:46 PM
