Compressor Surge
Old Jun 21, 2009 | 08:33 PM
Redlined RX8's Avatar
Red Liner
Compressor Surge
I just installed the Cobb Accessport so I needed to re-circulate my BOV. Now I’m getting a loud flutter noise every time I release the gas to shift. The noise gets louder and more obnoxious when I shift in boost. I currently have the MM Base map on right now so I didn’t go much higher than 1 psi. I’m sure it would be even louder if I went any higher. Due to the location and direction of the BOV and recirculation fitting on the Mazsport CAI, I had to pull off about a 180 degre angle as seen in the picture. The only thing that has changed aside from the EMU to Cobb is the recirc tube so I’m pretty sure that’s the problem. Does anyone have any suggestions on how to get rid of the flutter? I have a Greddy Turbo kit, synchronic BOV, and afore mentioned Mazsport CAI. Sorry for the picture I had to use my cell phone.
Old Jun 22, 2009 | 04:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
don't recirc. and see if it stops would be MY first test!
Old Jun 22, 2009 | 08:39 PM
czar's Avatar
Almost boosted
lol the pipes being all white kinda make it look like pvc pipe
Old Jun 22, 2009 | 08:50 PM
Red Liner
I'll try that tomorrow but I've been told the car won't run right or even at all when the AccessPort and VTA Synchronic BOV are used together.
Old Jun 22, 2009 | 09:02 PM
mysql101's Avatar
what kind of bov? recirculating won't cause compressor surge. If anything, recirculating usually makes the car run much more quiet.
Old Jun 22, 2009 | 09:09 PM
05rex8's Avatar
sold the 8... :(
make a vid
maybe it's not compressor surge you are hearing
mysql: it's the synchronic BOV
Old Jun 22, 2009 | 10:28 PM
mysql101's Avatar
ah, then it's not compressor surge. synchronic only seals shut when there is boost.
Old Jun 22, 2009 | 11:24 PM
Red Liner
I'll make a video tomorrow. It sure sounds like compressor surge...
Old Jun 23, 2009 | 01:56 AM
MazdaManiac's Avatar
"Flutter" at only 1 PSI is meaningless.
You will find it will get LESS fluttery as you add boost.
Old Jun 23, 2009 | 11:12 AM
Red Liner
I'm not sure what did the trick but thanks to Synapse Tech Support I changed to slightly larger ID vacuum hoses and loosened the screw in the back of the BOV and the sound is gone now. In fact, I can barely hear the BOV at all!
MazdaManiac: Will I need to redo my two log files or should we be good with the ones I sent you? My inspection sticker is already past due and I'd hate to loose my spot on your list.
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Nisaja
Aug 6, 2015 01:27 AM
iSki123
Jul 27, 2015 12:41 PM
