Upper/Center Dash Removal
Old Jun 21, 2009 | 11:55 AM
tksnobords's Avatar
TK
hey guys, i have been searching the forums for a while now. i am trying to find a DIY on removing the center top piece of the dash where the nav screen normally goes. i dont have the nav unit though. i am thinking of putting in a storage compartment there. how much room is under there? does anyone have pictures of it removed? anyway, if you could either point me to the right threads, or help me out...post here or email me @ tksnoborsd@gmail.com.
thanks in advance...
Old Jun 21, 2009 | 12:07 PM
expo1's Avatar
He's as bad as Can
try https://www.rx8club.com/series-i-do-yourself-forum-73/diy-whole-navigation-system-59957/
Old Jun 21, 2009 | 01:00 PM
shakeyourbrakes's Avatar
walk outside, get in the car, and pop the top center piece up and off. Start at the front and be carefull.
Thats the DIY
Old Jun 22, 2009 | 05:46 PM
tksnobords's Avatar
TK
oh ok. i pulled on it a little but didnt want to break it. so it just pulls up? cool thanks..
Old Jun 22, 2009 | 05:59 PM
tksnobords's Avatar
TK
finally i answered my own question! this is a link to the the removal instructions.
http://mnrx8club.com/viewtopic.php?f=18&t=128
tksnobords's Avatar
TK
shakeyourbrakes
me+your mom - condom= you
and thats funny as hell
Old Jun 26, 2009 | 11:56 PM
Spoolin8's Avatar
so does it just pull and pop right off or do you need to remove the lower and radio panels first?
Old Jun 27, 2009 | 01:01 AM
tksnobords's Avatar
TK
I'm not sure if you have to pull the radio, but I'm pretty sure the bolts for the upper/center dash are behind the heater vents...you might have to pull the radio to pull the heater vents...
Old Jun 27, 2009 | 09:45 AM
The center top dash piece doesnt have any bolts, just pops up and off...the only bolts are the one hidden one, which is a 10mm i think way up under the side up the dash by the drivers right leg, that goes into the side of the stock radio. Pain in the ***. . After the top is off, youll see the two screws on either side holding the top of the radio, and the heater vents to the dash.
The top section is off.
The lower section, unscrew the shifter ****, pop off the center console top (where the switches are) Take the screws out that hold the bottom of the ashtray assembly in place, and pull out the ashtray assembly. If im not mistaken, thats it, everything comes out of the dash. Total amount of screws and bolts 5 i think, and your dash is apart from the top center console, all the way to your center console. Hope that all helps
Old Jun 28, 2009 | 04:12 AM
tksnobords's Avatar
TK
there is two bolts in the bottom on this pic
Attached Thumbnails Upper/Center Dash Removal-attachmentyh7.jpg
Old Jul 2, 2009 | 02:49 AM
Spoolin8's Avatar
Ok so to just take off that top center piece i just pull forward and up? I tried the other day but couldnt get it off. Im thinking i just didnt pull hard enough but i was not sure if it had two screws holding it in place.
Old Jul 2, 2009 | 10:21 AM
You need to pull forward the stereo( OR REMOVE IT)...remove a couple of screws for the vents..pop them forward..and then remove the 2 screws that hold on the front of the upper panel
You can't remove it without removing the lower stuff without breaking it.......
Racingjunkie
Sep 29, 2015 05:05 PM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
