F/S RX8 Hi Compression Competition Engine Rotors Pics inside $700.00
Old Jun 19, 2009 | 09:06 AM
rob20rx7's Avatar
FL F/S RX8 Hi Compression Competition Engine Rotors Pics inside $700.00
Here is my second and last set of RX8 Competition Rotors. these are 10:1 compression and have been Lightened by removing .100 material from the inner rotor faces as well as have been race clearanced on both rotor faces. they have been match balanced and also cut to accept 3mm Apex seals. The bearings are in excellent condition. These rotors are ready to drop into your NA assembly for some major power. The black paint on the rotors is actually Graphite Spray used to protect the rotors from rusting while in storage.
Rotor Weights are
Front Rotor = 8.889 lbs
Rear Rotor = 8.902 lbs
Price is $700.00 Shipped
Old Jun 19, 2009 | 09:36 AM
rx8dorifto's Avatar
10:1???
thought stock were 10:1 already?
Old Jun 19, 2009 | 10:52 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
yes, they are just modified stock rotors.
Old Jun 19, 2009 | 11:17 AM
Highway8's Avatar
Registered RX8 Nut
So the stock rotor is about 9.2LBS which means these are approximately .3LBS lighter. Granted, most of that weight is toward the outside which will reduce centrifical loads but you might want to explain how loosing .3LBS of rotational mass can make "major power". I am not saying they wont, I just think a better explanation and estimation of power gains is in order. I am also awear that racing beat sells (or tries to sell) their 9LB rotors for $2100, however they dont claim "huge power" they say they help reduce centrifugal loads to improve bearing life AND reduce flexing of the eccentric shaft which help reliability.
Also, how many people have been running these rotors or similar rotors and with what success, Power and Reliabilty?
Old Jun 19, 2009 | 01:16 PM
rob20rx7's Avatar
Thumbs up
Originally Posted by rx8dorifto
10:1???
Yes, Stock Comp. is 10:1 i am just stating that info for those whom are not aware that these Rotors are the highest Compression Rotors available in comparison to other model years
I hope this helps.
Old Jun 19, 2009 | 01:29 PM
rob20rx7's Avatar
Wink
In essence, Major Power is merely an adjective in description to what Im selling. Major power is such a loose term that what may be Major to you may seem meaningless to me. No, you are not going to make Major power by just replacing rotors but by using these rotors along with other required and suggested Modifications to your engine you should see more power than you started with. As for the reduction in rotational weight… yes it does help as well as having your Rotating assembly Both Dynamically and static balanced as well.
Hope this helps..
Old Jun 19, 2009 | 05:59 PM
Highway8's Avatar
Registered RX8 Nut
Hope this helps..
So basicly for anyone having a performance rebuild or race motor built, these rotors would be a good addition to a package of upgrades including but not limited to, porting and improved seals.
Old Jun 20, 2009 | 05:42 AM
rob20rx7's Avatar
Smile
Bingo! Couldnt have said it better myself. LOL
vapor2
Nov 3, 2020 03:38 PM
ShadowGryphon
Jul 29, 2015 05:40 PM
dbarber
Jul 25, 2015 01:34 PM
Ryosuke-
12
Jul 24, 2015 12:51 PM
Bamaham
Jul 23, 2015 08:08 AM
