Front alignment bolts seized?
Old Jun 18, 2009 | 07:43 AM
balefire's Avatar
SCCA BS #35
I took my daily driver in for its annual autox alignment last week and the front alignment bolts appeared to have seized or stuck. We lubed it up, I drove it around for the past week and tried again the other day. Still no luck. Any suggestions?
I'm worried that we're gonna break the bolts and what not and I'll have a car that's out of commission waiting for parts from Mazda.
Old Jun 18, 2009 | 07:54 AM
it's been reported before
Old Jun 18, 2009 | 08:02 AM
Had to cut one side off...new control arm etc.....not a fun job
Old Jun 18, 2009 | 09:09 AM
mac11's Avatar
Rotary , eh?
buy the parts in advance so there is no downtime?
you're autoXing which means your part of mazda comp. right? shouldn't be that expensive to get the bolt, drill out the old one and replace.
Old Jun 21, 2009 | 12:27 PM
balefire's Avatar
SCCA BS #35
What parts had to be replaced? Would like to have the parts in advance so my daily driver is not out of commision for very long.
Old Jun 21, 2009 | 12:30 PM
mac11's Avatar
Rotary , eh?
Why not just get a drill bit and drill out the bolt so you only have to replace that?
Old Jun 21, 2009 | 01:12 PM
You will have a difficult time getting a drill in there.....but if you have a 90 degree adapter for an air drill it might fit. Then you only have to replace the bolt ( about $12) Otherwise you have to cut off the control arm...and replace that and the bolt.....( a lot more expensive)
Did you try an impact gun and a lot of penetrating oil.....you might get it loose that way if you are patient.
Old Jul 1, 2009 | 02:07 AM
just get a HD breaker bar (3/4" or larger with a 1/2" adaptor) and a long pipe for extra leverage, if the bolt breaks you're home free otherwise it will come loose
gwailo
May 14, 2024 06:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
