szym0n
06-17-2009, 09:07 PM
Well my clutch bracket broke on me monday, bought a new one w/ fluid sports bracket put it together but the problem now is that the screw that held my clutch bracket the first time it had broken is half and I had a stud and couldnt remove it...
So I drilled a new hole next to the broken stud and put a new screw to replace it but now, everytime i press the pedal in the bracket bends because the one screw is not enough...
So I drilled another hole about 2mm toward the engine but the metal is way to thin and does not give any support to the first screw..
I know this will not last long and will cause problems..
What can I do??
My friend suggested to weld the bracket to the frame...Good idea??
Ill post pix up of my problems soon.
What can I do??
