If I LOSE one more BEEPING race....help experts!
Old Jun 17, 2009 | 04:24 PM
ShottsCruisers's Avatar
Rx7 and now Rx8
ARGHHH! All my years racing around and shifting quickly, no car has frustrated me like my beloved 2006 GT.
WHAT IS THE FRICKIN' SECRET TO CONSISANT FAST 1st-TO-2nd GEAR SHIFTS WITHOUT GRINDING?
I learned right away in 2006 you can't pull the shifter at a slight angle toward you when shifting. GRIND!
I learned you have to pull the shifter STRAIGHT down. Trouble is, sometimes I still grind, especially if I shift FAST and at real high RPM's.
EXPERTS: What's the secret? I get the jump off the line then end up embarrassed when GRIND...................????
Old Jun 17, 2009 | 04:25 PM
I use a slight angle when I shift to 2nd... maybe your tranny is shot from trying to race every minivan off the line.
Old Jun 17, 2009 | 04:27 PM
Brettus's Avatar
Boosted Kiwi
meh - i never lose . See link below LOL
but to help with your problem . Try shifting a little earlier in 1st - say 7500ish . I garantee you will be be just as quick and never grind your gears
Old Jun 17, 2009 | 04:28 PM
benh's Avatar
try Redline Trans oil!!!
Old Jun 17, 2009 | 04:31 PM
Rx7 and now Rx8
Redline oil...will try.
And nope on the tranny abuse. I rarely race. Oh, I drive aggressively but when I do race I fear the grind because the thing is so sensitive. In my 3-years I probably have 6 grinds and the timing of some TICK ME OFF. Like yesterday's G35. Had him off the line and then GRIND...then the lane ended. CRAP!
Old Jun 17, 2009 | 04:32 PM
CyberPitz's Avatar
Huge hole is huge
Why would your drag lane end so early? Go to a new track, that will probably help you out.
Old Jun 17, 2009 | 04:36 PM
Rx7 and now Rx8
Oh ya. I follow ya.
Old Jun 17, 2009 | 04:41 PM
Socket7's Avatar
ಠ_ಠ
To go faster you must slow down. Brake later, accelerate sooner, give yourself more time to get into the next gear. Time is made in the corners, not during shifts.
If I catch you street racing in your 8, I'll personally steal your engine from you.
Old Jun 17, 2009 | 04:45 PM
Might not have anything to do with the transmission. I'm leaning more towards an electrical problem.
Are you sure the car is running at the required 1.21 gigawatts?
Old Jun 17, 2009 | 04:47 PM
Rx7 and now Rx8
Yes, I think you are 100% correct. On my past cars (Mazda Protege's, 323 and '82 Rx7) I could shift super fast and in one tug. This tranny doesn't like that into 2nd. It's almost like I have to shift in 2 movements.....1st to middle and down into 2nd. Like a pa-pa movement.
Old Jun 17, 2009 | 04:48 PM
Rx7 and now Rx8
Yes. 1.22GW. High output alternator.
Old Jun 17, 2009 | 04:50 PM
JTtheDude's Avatar
Also don't forget to turn the flux capacitor to 11.
Old Jun 17, 2009 | 05:15 PM
alfy28's Avatar
well there is a secret shifting. if your not following the exact sequence , then your whole race = fail.
Attached Thumbnails If I LOSE one more BEEPING race....help experts!-secret-shifting.jpg
Old Jun 17, 2009 | 05:18 PM
damn it Alfy, dont' give away the secret JDM shifting pattern!!!
Old Jun 17, 2009 | 05:27 PM
alfy28's Avatar
[QUOTE=Jedi54;3074312]damn it Alfy, dont' give away the secret JDM shifting pattern!!![/QUOTE]
lol
Old Jun 17, 2009 | 05:37 PM
dozer's Avatar
on his 3rd rx8
^soooo that the way your supposed to do it
i always thought 1st gear was to push down on the shift, and go all way to the right then down...i heard that the best way to launch was to rev to 9k and SLOWLY feather the clutch
Old Jun 17, 2009 | 05:39 PM
alfy28's Avatar
i am not sure who taught you how to drive dozer. but you have been doing it all wrong. i suggest you follow the diagram that i layed out eariler. its the secret to success.
alright, fine!!!!
If Alfy is going to give away the super secret JDM shifting pattern then I guess I should tell you how to NEVER lose another race.
All you'll need is THIS!
Old Jun 17, 2009 | 05:40 PM
Please delete your post Alfy.
Old Jun 17, 2009 | 05:42 PM
Socket7's Avatar
ಠ_ಠ
Sounds about right for 2nd gear IME. IT has almost double the RPM drop then all the other gears do, so you just got to give it time for the syncros to line up and it will drop in like butter. You'll be letting the revs drop from 9K to about 6.5 anyways for a smooth transition, so make use of that time by shifting slower. Do it right and it should feel like you just got picked up by a tsunami that's pushing you through second gear. You shouldn't loose much time either.
alfy28's Avatar
alright, fine!!!!
lol seeing this pic reminded me count dracula from seasme street. you should add him to the pic
Old Jun 17, 2009 | 05:48 PM
04RX8man's Avatar
Rotary Powered Countryboy
Street Racing is wrong!!!......"closed course racing" for purposes on this forum is A. O. K.
Old Jun 17, 2009 | 07:41 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
No your problem is you're living in 2004 and still think your 8 has a chance against a G35.
Old Jun 17, 2009 | 07:44 PM
newguy's Avatar
zoom fuckin zoom
every time Ive redlined 1st to 2nd i had no grind maybe you have a worn syncro
Old Jun 17, 2009 | 07:50 PM
dozer's Avatar
on his 3rd rx8
thanks for the great advice alfy, ill be using your method from now on
