Need advice on map lights
Old Jun 14, 2009 | 09:46 PM
JinDesu's Avatar
went back to srsly broke
So I tried to remove the 2 screws for the map lights, and found them incredibly difficult to take out. I got the one on the right side out, but after about 20 minutes of trying, I gave up on the left side.
I also realized that I might have stripped the screw a little, as I can no longer apply torque to it. Does anyone know what I can do to get it out? Google results in suggestions such as heat it (torch it), stripped screw remover, superglue a screwdriver to it, and some silly suggestions. However, since this is inside the car, I can't torch it.
Should I use a stripped screw remover and buy a replacement screw from home depot? Or is there a better solution? Thanks for any replies.
Old Jun 14, 2009 | 09:56 PM
I would replace the screw. You need to use the right number screw driver head.
Old Jun 14, 2009 | 10:00 PM
JinDesu's Avatar
Ok, I'll take a look at my local hardware stores for screw removal kits.
Old Jun 14, 2009 | 10:03 PM
Also either get a decent screw driver set or get a socket driver with numbered screw driver heads. They will save you a lot of aggravation.
Old Jun 14, 2009 | 10:07 PM
JinDesu's Avatar
I plan to, my dad's old set isn't enough
Old Jun 14, 2009 | 10:10 PM
My gramps used to always say, "You can judge a craftsman by his tools"
Old Jun 14, 2009 | 10:21 PM
NoOdLe BoY's Avatar
so what does that say about me and my Husky Black Chromed set? lol
RevMeHarder
Jun 1, 2026 02:30 PM
Azki23
Jun 27, 2018 03:48 PM
yapakanichi
Sep 17, 2015 04:23 AM
TJSiegrist
Sep 10, 2015 09:29 AM
