View Full Version : Which lightweight battery?
bse50
06-14-2009, 05:07 PM
Well, after 4 years my battery is starting to work improperly so i thought that it would be a good idea to replace it with a light weight one considering that i seldom use the car's audio system and lights. I also track my car often enough to justify the small sacrificies that this kind of battery needs you to do.
The problem is, which one to buy?
I don't need a no-weight battery, i would like it to be less than 22pounds or so and capable of starting the car after a week of absolutely no use.
Any suggestions? I know that Braille makes this kind of battery but any other quality product is welcome. A model number would be even further appreciated ;)
Thank you!
04RX8man
06-14-2009, 06:43 PM
I say go with Braille prob the lightest that u will find.....but I don't have the cash for that so i stick with DieHard ahah...but that s not at all lightweightt
bse50
06-15-2009, 04:19 PM
Yep, i would like to receive a little help about the model too :)
It should keep the charge for at least 7-10 days.
Thank you anyway!
Psychofox
06-15-2009, 09:05 PM
try odyssey pc680
bse50
06-16-2009, 02:55 AM
You made my day, it is sold in italy! ;)
17amp\hr though... must have a look at their whole range
TrochoidMagic
06-16-2009, 03:45 AM
^^if u want something for street use reliability, try odyssey pc925mjt. 25lbs, modify new b+ terminal wires and tap the stock tie downs to sit the battery lower. and punch holes on the side covers for the tie down protrusions...
just a recommendation...
