How do I remove or open the front headlamps?
Old Jun 12, 2009 | 08:57 PM
BigMikeATL's Avatar
I have a little moisture trapped in one of my headlamps and want to open it up, let it dry out, seal the small crack letting moisture in, and reattach it.
Thanks in advance!
Old Jun 14, 2009 | 08:48 PM
BigMikeATL's Avatar
Anyone?
Old Jun 14, 2009 | 08:56 PM
Alexb's Avatar
desperately needs a drop
welllll...
First. you'll have to get the whole fixture out of the car.
Idk how to do this. But search, you'll find something.
Then. This is where it gets interesting. You have to bake them (yes bake, like a turkey) and the lens will come off. Allowing you access.
It's quite a lot of work. You probably have a bad seal on one of your bulb fixtures. So if it were me. I'd try to take out the parking bulb or main headlight bulb and see if I could vaccuum it out or stick a towel or something to get it out. Because if not you could potentially ruin a headlight. and they are about $400.
In the end. is it worth it? Another way to fix it may be to take the taillight fix. Take the fixture out and drill some holes at the bottom (very small holes mind you) and the water will go out... hopefully.... also search for that...
Basically, search for these methods and you'll figure it out.
Hope this helps!
Old Jun 14, 2009 | 09:09 PM
MazdaEight's Avatar
You have to remove the front bumper, and then you can unbolt the headlight. Like Alexb said, you will have to bake it..then it will peel apart. Have fun if you have HID equipped headlights, it won't be easy to disassemble. I had mine out and was gonna do the same, but the task of taking out all of the wiring seemed to be a lil much. Plus I did'nt want to take the chance of messing it up, I had a light quoted at $1400 to replace.
Mazurfer's Avatar
Surf Hard, Drive Hard
Yep, go to the DIY section on this site and do some searching, you will see that it is just about the only way.
Old Jun 14, 2009 | 09:17 PM
Alexb's Avatar
Unless you have a pond in there.. I'd suggest just living with it. It came in some way. maybe it will find it's way out. Another Idea I had was to take the headlight out. But w/o baking it, see if you could dump it out through a hole that a bulb goes in. Or freeze the assembly and see if you can make the ice fall out or pull it out.
Old Jun 14, 2009 | 10:03 PM
shakeyourbrakes's Avatar
its not a major process...search my old threads for halo DIYs, I have all the instructions to open them. OR just take the headlight off the car, get a blowdryer in the light sockets and dry that water out...then reseal the edges with a clear silicone. There ya go, problem gone
Old Jun 19, 2009 | 03:41 PM
04RX8man's Avatar
Rotary Powered Countryboy
blowdryer may work
Old Jun 19, 2009 | 03:57 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
or just get a new headlight assembly if you mess up
just take off the front bumper and unbolt it. ive done it a few times.
lotz of hardwear but should take 15 mins to do so.
Billy Marcial
Mar 1, 2018 06:50 AM
Solidtrance
22
Sep 4, 2015 12:47 PM
blkswan
Jul 30, 2015 10:55 AM
ktec
Jul 29, 2015 01:17 PM
