Help! Ordered wrong tire size
Old Jun 10, 2009 | 07:57 PM
kimmy's Avatar
I ordered two 225/45ZR18 Kumho Ecsta LX Platinum for my 2004 Rx 8 (from Tirerack) not realizing that I had been running 4 225/55 16 OEM Bridgestone Protenza.
I only have 20000 miles on the tires and they started getting dry rot where the grooves recess on the bottom of the tire, about 3 years ago, so decided to not replace w OEMs.
Im assuming I cant just replace 2 of the OEMs, and I am not sure now if I want to exchange them with the same tire size.
My concern is !) will the 18s run better than the 16s in the snow and 2) which would be better for gas consumption.
Thanks in advance
Kimmy
Old Jun 10, 2009 | 07:58 PM
invasion08's Avatar
What size rims do you have the 16inch or 18inch?
Old Jun 10, 2009 | 08:01 PM
dmp's Avatar
dmp
RX8 and a Truk....
well - the 18s will NOT EVEN WORK on your wheels...so the issue of if they will work 'better' is moot. You'd need to buy 18" wheels.
Old Jun 10, 2009 | 08:02 PM
expo1's Avatar
He's as bad as Can
Originally Posted by invasion08
Call up tire rack and change the order. When did you order them?
+1
I am also going to guess you do not have any 18" wheels so if you were to keep the 18" what would you mount them on?
They should perform the same as they are the same specs IIRC. So are you saying you have sets of both 18" rims and 16" rims?
Old Jun 10, 2009 | 08:04 PM
invasion08's Avatar
If you car has 16 inch rims you will need to get 225/55/16. Do you understand what the number stand for?
225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel
55 indicates that this tire size's sidewall height
16 indicates the tire and wheel diameter designed to be matched together
Old Jun 10, 2009 | 08:06 PM
kimmy's Avatar
I have the 16" rims so that pretty much answers my questions...thanks for your input!
Old Jun 11, 2009 | 01:30 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Hope you can return them or get some money for them.
ladnarf1
Apr 29, 2021 11:53 PM
rx8inator
Sep 1, 2015 07:18 PM
Shinka84
Aug 19, 2015 04:55 PM
GK1707
Aug 3, 2015 10:23 PM
