View Full Version : help !!! wont go into gear
menacerx8
06-09-2009, 05:26 PM
i've replace the clutch slave cylinder and ss clutch hose and bled it start it up and it wouldn't go into any gear?? but when i started the car up in 1 gear drive it fine for alittle then it start to f*** up and wont go into gear :icon_no2:
Razz1
06-10-2009, 09:35 PM
May not be bled correctly.
Try rocking the car, that always work. then you can move the shifter into gear.
menacerx8
06-15-2009, 12:31 AM
replaced the clutch master and try to bled it now there no clutch pedal pressure??? can't find any leak pump the pedal for like 1 hour
Razz1
06-15-2009, 10:40 PM
buy a bleed kit at Harbor Freight or an auto store.
It will remove the air.
menacerx8
06-20-2009, 02:52 AM
i tow it to the dealer and have them bleed the system for me. they told me it wouldn't go into gear. dealer told me it could be the pressure plate. they gonna check and make sure but what you think???
