Leshil
06-08-2009, 10:21 AM
I installed some new stuff this past weekend which I thought went okay, but after I installed the Esmiril ignition upgrade, new spark plugs, new ignition coil wires and AEM CAI, I seem to get really bad gas millage and I get a popping during acceleration. Any ideas?
Grungepup
06-08-2009, 11:27 AM
when i did my MS CAI install, i dropped about 2mpg ..... as far as the popping no idea
dillsrotary
06-08-2009, 11:55 AM
any more details? most of the time it maybe a small flaw somewhere in your install, did you verify and double check everything accordingly?
alienRX8
06-08-2009, 12:03 PM
bad gas mileage and popping sounds like you are now running rich, double check you installs that you didnt leave any vaccum hoses off and double check all the connection on the ignition
05rx8mazda
06-08-2009, 12:09 PM
check the coils first... as for the intake it will have no power on acceleration.. usually around 5k rpms.. popping sound is more to do witht he ingiton or the plugs. double check the wires and the plugs making sure you didnt switch them up.. happened to me once lol
Razz1
06-09-2009, 12:06 AM
Front and rear trailing plugs are swapped or the coil wires.
check those items too.
Flashwing
06-09-2009, 03:18 AM
The Esmiril ignition upgrade normally requires splicing of your harness to get it hooked up. If this was done you may want to check your wiring to ensure there's no issues.
I agree that you could be operating with a non-firing coil that would cause incomplete combustion.
PSTNLSS
06-09-2009, 09:54 AM
Shoulda went with the BHR ignition=] I don't have it but I heard good things!
Leshil
06-09-2009, 07:21 PM
It seems to have been an issue with the spark plugs themselves. Bought stock ones and my problems stopped. Also, I have the BHR harness for the ignition coils so I didn't have to deal with the splicing. :lol:
