Whistling noise when in D and R.
Old Jun 8, 2009 | 07:56 AM
SilverRenesis's Avatar
Has anybody found a solution to this problem. I've seen maybe 2 topics regarding this whistle noise coming from under the car, but I have yet to see someone with the real answer on why does this happen, or what is it. Does anybody know?
Old Jul 7, 2009 | 12:55 PM
Naybody please, The problem is getting worse.
Old Jul 7, 2009 | 01:04 PM
jmc23200's Avatar
If you have made two different threads about the same topic, and no one has been able to help you, it's time to admit defeat. Sorry buddy, but it sounds like your are SOL. When in doubt, bring it to the dealer. Pay the $100 and let them tell you whats wrong. Then, you can do the work yourself. Good Luck.
Edit: If this only happens when you are moving(D,R) then we could take a guess and say it may be the diff. I wonder if it is the syncros giving the loud whine.
Old Jul 7, 2009 | 01:15 PM
Easy_E1's Avatar
Your going to have to give us more info as to when this is happening. Are you moving or are you sitting still? Does this occur while driving or at an idle?
I'm thinking engine mount. Pull up to a wall on the drivers side of the car. Roll the window down. Now put the car in 1st gear and listen. Then put the car in second gear and listen. Do you hear anything unusual? Does the sound change when you change gears?
Old Jul 7, 2009 | 01:24 PM
jmc23200's Avatar
Apparently I posted in your other thread for the same problem. Here we go. First, get another person to help you pin point the sound. While you go from N to D have someone else look to see if they can hear where the sound is coming from. Once you can pin point the sound, let us know what region it is coming from. Get a pic of your engine bay and show us.
Again, I had a similar issue and it ended up being my belts or pulleys, not sure which. I took a can of Belt Dresing and gave them a quick squirt and the noise has stopped for 9 months.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
