Tires Causing Rear End Issues?
Old Jun 3, 2009 | 07:28 PM
MP3Guy's Avatar
After 35,000 miles and many years on this forum, I need some advice.
I installed Continental all-season tires on my car after giving up the ghost trying to get through winter with the stock Potenzas- no big deal, they needed replacing anyway.
However, I find that when I do hard cornering, the rear tires "lock up" intermittently and I hear a clunk from the rear end.
Turning off the DSC eliminates this issue completely. I never had this problem with the Potenzas. Is this normal?
Old Jun 3, 2009 | 09:18 PM
Cam's Avatar
Cam
this space for rent
did you change tire sizes?
A change is size can cause ABS issues.
Old Jun 4, 2009 | 11:56 AM
Nubo's Avatar
Lubricious
The all-seasons will have less ultimate grip than the Potenzas, so TCS/DSC will kick in earlier than you were used to. You may need to adjust your tire pressure. I replaced my original Dunlops with Yokohama Avid all-seasons. It's not quite the racecar that it once was, TCS/DSC will kick in sooner, but still handles quite well; just don't take it to the track .
On the plus side, I now have plenty of traction in cold and rain and feel much safer in those conditions. And lo and behold, TCS/DSC kicks in much LATER in those conditions. Meaning, I sacrificed a little ultimate grip in summer in exchange for a big bump in grip in situations which were dangerous before. A great exchange, imo.
I found I needed to run a couple more PSI than I had been with the OEM tires to get the best handling out of them.
Old Jun 4, 2009 | 06:52 PM
MP3Guy's Avatar
Thanks for the help guys- I'll try a few more PSI in the rears and see what happens. In the meantime, you should see how adept I have become at shutting off the switch mid turn. Don't even have to look, and I don't have to tell you how weird that is given where the switch is.
Old Jun 5, 2009 | 10:41 AM
renesisgenesis's Avatar
mod edit
why not just keep the DSC/TC off?
Old Jun 5, 2009 | 06:03 PM
rx8cited's Avatar
Senior Member
Not a good idea to disable a safety feature 100% of the time. I'm sure there are those who drive with with it a disabled all the time, but I would not want to.
New Yorker
40
Mar 22, 2022 06:01 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
thewatcher101
Jul 27, 2015 09:44 PM
