285 Hoosier a6 tire pressures???
Old Jun 3, 2009 | 07:14 AM
conekiller2's Avatar
For those of you running the 285 hoosiers, what tire pressures have you found optimal
Sacha
Old Jun 3, 2009 | 07:36 AM
Zoom4Three's Avatar
"Optimal" will be surface, car set-up and driving style dependent. The typical range for a B-stock prepped car (including max. negative front camber) is 36 to 44 psi, hot pressure.
Chris H
Old Jun 3, 2009 | 08:15 AM
Thanks Chris. I actually currently have kumhos on the car but from past experience i know the kumhos run about 1-2lbs less than hoosiers with everything else the same. This past weekend i ended up at 36 frt and 34 rear so im pretty close and the car felt good
Old Jun 3, 2009 | 11:25 AM
mwood's Avatar
We ended up at 40f/42r with the 285. Slightly higher rear pressures will help with the off corner push that many of us encounter with the typical RX8 BS set up.
Old Jun 18, 2009 | 07:00 PM
philipchan's Avatar
Hot 40~42
EricMeyer
RX-8 Racing
61
Feb 17, 2010 09:33 PM
conekiller2
RX-8 Racing
12
Mar 23, 2009 08:43 PM
Matt RX8
RX-8 Racing
12
Jul 17, 2008 06:34 PM
Chris_Bangle
RX-8 Racing
10
Jun 7, 2008 11:09 PM
Cito
RX-8 Racing
26
Aug 7, 2006 04:03 PM
