View Full Version : Cant figure it out- idling like crap
remixlp
05-30-2009, 02:15 AM
About a month ago my motor got blown due to FI.
I ordered a new motor and returned my car to stock about 4 days ago. Here is the kicker.
I was driving today and my car stalled in traffic. I started it back up and it is idling rough and a loud knocking sound is coming from the passenger wheel. I checked the coils, sparkplugs and checked for vacuum leaks; All of which checked out fine unless I'm missing somthing.:banghead:
Later i cleaned the MAF sensor and the car ran good for about 10 minutes, then back to running like crap.
ok I ran a test and got these error codes
PO113
PO171B
PO300B
PO507
PO302
I changed the coils and wires and the car is still shaking while idling. It seems to rev fine, but im still getting a misfire.
carbonRX8
05-30-2009, 08:56 AM
Is the motor mount loose on the pass side? I have heard that the knock sensor likes the sound of an engine on busted mounts and will create all sorts of havoc. Like what you are seeing.
May I ask, why go back to stock? I figure it would have been a golden opportunity to boost higher.
remixlp
05-30-2009, 02:35 PM
The car just idles rough and the engine is seems to me rocking side to side slightly. I'm gonna check the motor mount today.
I went back to stock because the first motor blew lol.
ZumnRx8
05-30-2009, 02:38 PM
SHould have order a Street Port Engine from RotaryPower and put your FI back on, what did you do with your FI? Are you gonna sell it?
remixlp
05-30-2009, 02:42 PM
I already sold it. I plan on using a different kit soon.
ZumnRx8
05-30-2009, 03:05 PM
PETTIT or HYMEE? or HKS....<----pick this one :yesnod:
remixlp
05-30-2009, 08:36 PM
^^Maybe sometime in the future.
I added error codes from a test i ran today.
remixlp
06-01-2009, 11:57 AM
Any help?
Race Roots
06-01-2009, 12:13 PM
PO113 - IAT sensor circuit high input ON 1 CCM
PO171B - System too lean ON 2 Fuel system
PO300B - Random misfire detected Flash/ON 1 or 2 Misfire
PO507 - Idle air control system RPM higher than expected ON 2 CCM
Should get you in the right direction...
remixlp
06-01-2009, 12:54 PM
Cleaned MAF
Replaced Coils, wires and plugs
Time to check fuel pump.
Phish806
06-01-2009, 12:57 PM
What did you do with the blown motor??
remixlp
06-01-2009, 01:11 PM
in my friends garage.
Phish806
06-01-2009, 01:37 PM
what actual damage was done to it? Apex seal or something more?
remixlp
06-01-2009, 08:42 PM
we have yet to open it. I just got pissed and bought a new engine which just happens to be pissing me off right now lol.
Phish806
06-01-2009, 10:09 PM
Just out of curiosity ... you do a compression test on it?
Race Roots
06-02-2009, 02:52 PM
Pull the Injectors and check them as well, the car running lean could be from that which would lead to misfires....
I was experiencing this same issue recently with a supercharged RX-8.
That is if you Fuel Pump is good.
