Worst Day
Old May 29, 2009 | 04:17 PM
Spiker's Avatar
Worst Day
So the hing in the window visor is broke and the whole time it was spliting up the panel. I just realized that it was broken down because it is hanging down. I could not get it to work so I pull the wire out from the visor. Now the radio/door electronics wont work and the engine light is on...anyone got any ideas?
Old May 29, 2009 | 04:27 PM
Sleepy-z's Avatar
check your fuses perhaps, i dunno.
Alexb's Avatar
desperately needs a drop
You just yanked it out...
Old May 29, 2009 | 04:34 PM
boizart1's Avatar
lol would have liked to see ur face when u asked this question
Old May 29, 2009 | 04:39 PM
Spiker's Avatar
No I split the panel and removed the wires. Where do I find the fuses? Btw next week I have alot of important stuff. You think i can still drive with the engine light on?
Old May 29, 2009 | 04:44 PM
JinDesu's Avatar
went back to srsly broke
Face your engine, lower right side of the car. It's got a cover. Search the forum, you'll find a picture.
Old May 29, 2009 | 04:51 PM
Spiker's Avatar
How exactly do i reset the fuses?
Old May 29, 2009 | 04:54 PM
JinDesu's Avatar
I'm not sure, but how did you remove the wires? Did you pull them out? Cut them? Disconnect them at a point? If they were disconnected properly, there's no reason for those lights to come on and for your electronics to not work.
Old May 29, 2009 | 05:00 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
You should have searched on here before you yanked. I think some other people had similar issues. The visors suck. They redesigned up last year.
Old May 29, 2009 | 05:28 PM
Spiker's Avatar
well there is a thing you push on the wire to disconnect them. I not sure maybe in the process they touched eachother. I just checked the driver fuse box and replace a fuse and it didnt work. I dont know how to pull out the fuse in the engine compartment to check them out. (however they seem to be fine).
Old May 29, 2009 | 05:58 PM
Spiker's Avatar
Called the dealer and they said is going to cost about 300$....and holy crap their design of the visor is so stupid..I can make a better one than that..
Old May 29, 2009 | 06:34 PM
User24's Avatar
Just tape those leads to keep them from shorting each other out. And go no visor to save weight. Why pay money for plastic crap that's just gonna break eventually? Might as well have gone elise if you want to keep fixing flimsy plastic parts.
Old May 29, 2009 | 06:39 PM
OOh burn
Old May 29, 2009 | 11:32 PM
Spiker's Avatar
The electric system is broken says the dealer on the phone which cost 300
and the panel itself cost 100...
Old May 30, 2009 | 12:06 AM
tderse's Avatar
Bulletin No: 09-002/07
I just had my visor fixed under warranty. This is the service bulletin number. Hope this helps. It's a known problem.
Old May 30, 2009 | 12:28 AM
Spiker's Avatar
Yea thx that helps! now anyone knows how to get the other 300$ back? x.x
Old May 30, 2009 | 12:59 AM
Keyten's Avatar
I did the absolute exact same thing. My visor broke and was hanging down so I tried to tear it off because it was in the way of my vision.
Turns out that the wires that lead to the light in the visor were not coated at the ends so the wires crossed and I though I burnt out my electrical system. The radio wouldn't start and I do think the automatic locks did either. Anyways, I took it to the dealer and played stupid and said it fell off. Mine was under warranty and hopefully yours is too. It just ended up being a blown fuse and they swapped it out in a few minutes and I was on my way.
If yours isn't under warranty, then there is a good chance they are trying to sucker you out of some money.
Old May 30, 2009 | 09:18 AM
Spiker's Avatar
Do you remember which fuse they broke? like which fuse box is it in? I check the driver side and it is fine. I dont know about the engine side. Also did your engine light come on?
Hiroshima_RX
Sep 21, 2015 06:28 PM
mitchrx8
Sep 13, 2015 08:05 AM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
