Rotory Lotus
Old May 26, 2009 | 01:12 PM
Danks420's Avatar
Cruising150
Rotory Lotus
does anyone think it is possible to put a rotory engien in a lotus casue a 13b would be tight and a 20b we be tight as ****!!!!
Old May 26, 2009 | 01:19 PM
RyanX-8's Avatar
2004 Titanium Grey GT
I think a 13b would fit... i am not a mechanic tho.
Old May 26, 2009 | 01:30 PM
alfy28's Avatar
hmm if a miata can hold a 13b with ease, i would think a elise can also.
Old May 26, 2009 | 01:32 PM
Danks420's Avatar
Cruising150
a turbo wouldn't fit after though right? that would be the greatest car of all tiem- but would it slow the car- cause i think the 13b engine is hevier then the lotus it would definatly be worth it with a turbo thoguh
Old May 26, 2009 | 02:14 PM
alfy28's Avatar
Umm why would it be slow? the lotus weight alone with a light engine still would be fast. i really do not think a turbo would be needed.
Old May 26, 2009 | 03:02 PM
ODDDOOD's Avatar
The DOOD abides.
I thought the Elise used the old celica/tC 4-cylinder...it is aluminum but I still think the rotary would have a much lighter weight.
https://www.rx8club.com/showthread.p...sis+dry+weight
Old May 26, 2009 | 03:07 PM
alnielsen's Avatar
I don't know about the weight, but it could lower the Center of Gravity. This would depend on how it was installed.
Old May 26, 2009 | 03:59 PM
GotBass's Avatar
Still plays with cars
Anything is possible if you have enough time and money.
Lotus needed to go with a transverse engine/transmission setup for their car. The rotary was never designed for this application so the biggest problem is going to be mounting it up to a FWD transmission. After that you'll have to fabricate an engine supframe and then there is still wiring. Like I said serious time and money.
Old May 26, 2009 | 04:01 PM
Spinning Sushi's Avatar
I <3 Sushi
[EMBED]MwU3hrcj57s[/EMBED]
It's not an Elise but it's still a Lotus.
Old May 26, 2009 | 04:54 PM
Rotr8's Avatar
whines all the way home
theres a local guy near me that always showed up at the autoX's with a Caterham with a twin turbo 13B, the thing could barely ever hold traction...
Old May 26, 2009 | 06:36 PM
alfy28's Avatar
MA
ty fro the sahre SE3p
Old May 26, 2009 | 06:37 PM
I <3 Sushi
You are most certainly welcome my fine sir.
Old May 26, 2009 | 07:55 PM
rafaga's Avatar
How about an ariel atom with a 13b?
Old May 27, 2009 | 01:32 AM
haha that would be legit
Old May 27, 2009 | 02:34 PM
CyberPitz's Avatar
Huge hole is huge
What, do you want to KILL people??
Old May 27, 2009 | 03:52 PM
Klone's Avatar
The motor in the Elise is fine, it is lightweight and it gets good gas mileage. Add a supercharger, or turbo and you can get anywhere from 220 to over 400 whp. Adding a k20 is hard enough, I can't imagine adding a rotary. The car is very quick already, I would rather spend $6000 on a good supercharger and tune then a motor swap. It has been discussed on the Lotus forums repeatedly, but it always comes down to money and time. Most have realized it is not worth the effort.
Old May 27, 2009 | 04:04 PM
EdwardsB's Avatar
Registered RX-8 User
if you have the money to do this and are worried about weight of the engine...get the RB aluminum housings to replace the cast iron ones...reduces the 13b block weight to 109 lbs.
Old May 28, 2009 | 06:06 PM
LionZoo's Avatar
road warrior
The 2ZZ used in the Elise is heavier than the 13B-MSP by 10 pounds. However, the 13B will need more auxiliary hardware as Mazda also runs two oil coolers while Lotus runs one cooler for their 2ZZ.
Old May 29, 2009 | 07:14 AM
Danks420's Avatar
Cruising150
dont have the money jsut dreaming lol like ussual
Old Jun 1, 2009 | 08:05 AM
pugg57's Avatar
proper motoring
I would think that it would be pretty great with aluminum housings, but tail heavy with the stock steel ones. That being said, I'm not sure the 13b-rew would do too well in the back end of my car without some SERIOUS ducting to sweep away heat. as it stands, the car is over-cooled though, so I could be wrong. it would be alot of fun! all aluminum housings, a GT35R turbo, good intercooler ducted from the roof scoop... mmm...yeah, that'd be great.
Jesus Martinez
72
Jul 26, 2023 11:29 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
Bill_Monteith
Aug 18, 2015 07:11 AM
Supercharger
General Automotive
25
Oct 6, 2003 07:03 PM
