I need help/ opinions...pictures to help out
Old May 24, 2009 | 02:34 PM
04blue8's Avatar
zoom zoom
Unhappy I need help/ opinions...pictures to help out
i just noticed this morning that i had a couple of drip spots on my driveway. i jacked the car up and noticed that oil was dripping out of the bolt just above the oil plug. so i am lost the bolt was on tight but it looks like it might not be coming directly from the bolt....what do yall think it is??? the red arrow shows where the drip is exactly...
Attached Thumbnails I need help/ opinions...pictures to help out-dsc02318.jpg   I need help/ opinions...pictures to help out-dsc02321.jpg
Old May 24, 2009 | 03:25 PM
invasion08's Avatar
First Clean the oil off. I think the oil you see is from your motor mount that has cracked. I could be wrong. Do you notice rough idle? Look at the motor mount and see if you see any oil up there. The bolt from the aluminum engine mount bracket does not go into the oil pan.
Old May 24, 2009 | 06:34 PM
04blue8's Avatar
zoom zoom
it idles a little rough...i thought it was because of a bad coil and i dont have money at the time to replace it
Old May 24, 2009 | 08:47 PM
invasion08's Avatar
More info about the car, Year Mileage, Mileage on the spark plugs and coils.
Old May 24, 2009 | 08:53 PM
04blue8's Avatar
zoom zoom
2004, 9k on new engine, spark plugs and coils idk...got it used. its a manual if that matters.
Old May 24, 2009 | 08:56 PM
invasion08's Avatar
I bet the motor mounts are shot and are going to need new ones. Did you get a warranty with the car. But Clean the oil off first and see if it comes back again.
Old May 24, 2009 | 08:58 PM
04blue8's Avatar
zoom zoom
fml....warranty no....and i cleaned it off right after it took the pictures. i left it on there so it was easier to see
Old May 24, 2009 | 09:01 PM
invasion08's Avatar
If it looks like the oil is coming from that bolt see if you can tighten it alittle more. Maybe that will stop it
Old May 24, 2009 | 09:05 PM
I8U's Avatar
I8U
It's a motor mount bolt, no oil is coming from it. You need to get it on a lift and see if the oil is coming from the engine itself. Maybe you spilled a little oil when you added? It doesn't look like a lot of oil to begin with. Have you checked your oil level is it lower than normal?
Old May 24, 2009 | 09:46 PM
04blue8's Avatar
zoom zoom
AZ
Originally Posted by I8U
It's a motor mount bolt, no oil is coming from it. You need to get it on a lift and see if the oil is coming from the engine itself. Maybe you spilled a little oil when you added? It does look like a lot of oil to begin with. Have you checked your oil level is it lower than normal?
i know i had spilled a little oil when i changed it about two months ago...but i doubt it would be oil from that? the oil level was a little low but nothing out of the ordinary..but i have been driving it really hard lately (i was enjoying the rain and cooler weather before it gets 116)
pup
Feb 5, 2015 12:19 PM
landsfeldrx8
Apr 21, 2014 02:26 PM
msherman1
Purchasing, Financing, & Insurance
Sep 26, 2012 08:38 AM
tuner321
Mar 10, 2012 08:25 PM
eldog
May 29, 2006 03:22 PM
