axle spline
Old May 23, 2009 | 02:58 PM
warick101's Avatar
axle spline
Can anyone tell me the halfshaft diameter to the hubs for the RX-8 axles?? Is it 26mm like the TII RX-7 or 29mm like the RX-7 TT, or something else?
Thanks,
Aric
Old May 24, 2009 | 09:58 PM
warick101's Avatar
Thanks, 800hp axles would be great, but I only need 300-400hp axles. I'm swapping the rear out of a Renesis Miata conversion and trying to decide which way to go with it. I have a full TII rear end w/o stub shafts, and a spare FD rear end and axles I could use. The issue comes down to cost and PITA factor in getting my axles to fit my hubs which are set up for TII axles. Using a FD/RX-8 rear end would be a cleaner install for a custon PPF over the TII rear though. If the RX-8 axles have the same diameter and spline as the TII axles at the hub, I'll get a pair of those. If not, I'll have to get my FD axles machined. Or, find a pair of TII stub shafts to finish off the TII rear end I have. Choices, choices...
BERG
Oct 8, 2015 09:28 PM
shambo
Jul 18, 2015 02:07 PM
dillsrotary
General Automotive
13
Sep 15, 2006 09:50 PM
RX8_Buckeye
Mar 24, 2005 10:47 AM
