rubber accordian tube for intake
Old May 22, 2009 | 04:59 PM
kersh4w's Avatar
Hit & Run Magnet
i had to ship mine off. so currently im running a short ram attached straight to the throttle body. attached with... duct tape.
its attached well, but the three hoses that attach to the accordian i taped off with duct tape. so it runs. but it makes high pitched noises.
how important are those hoses? and until i can get my aem, is it ok to leave them capped? or should i get little air filters at autozone to attach to them?
Old May 22, 2009 | 05:10 PM
Jon316G's Avatar
Grasshopper
The high pitch noise if probably coming from the oil breather hose.
I recall someone posted a video with it.
2nd hose goes to the intake manifold.
There are two "tubes" that extended into the engine where the primary intake runners are.
My belief is that this is to relief pressure in the block (correct me if I'm wrong).
3rd hose goes to a manifold for the VDI, SSV, and AIR solenoid.
This might be the most important to have since it needs vacuum to actuate the valves.
Old May 22, 2009 | 06:28 PM
Nemesis8's Avatar
Bigus Rotus
I would say the one that goes to the oil metering nozzle manifold is the most important. If you do not have your VFAD hooked up, you could manifold them all together and use the VFAD nipple behind the throttle body for a vacuum source.
Jon316G's Avatar
Grasshopper
Damn... you're right Charles.
The hose for the VDI, SSV, and AIR solenoid is on the UIM, not the accordion tube like I mentioned above.
Good catch there... I need more caffeine!
Old May 22, 2009 | 08:12 PM
kersh4w's Avatar
Hit & Run Magnet
my vfad is not hooked up. great idea, i'll see if it fits.
which hose is this?
btw, car runs "fine" like this. some stumbles coming to a stop though.
Old May 23, 2009 | 08:54 AM
kersh4w's Avatar
Hit & Run Magnet
well i was only looking for the omp hose to connect it to the manifold. i wasnt going to manifold them together. but if no one knows, thats ok. hopefully its going to be this way just for a few days.
Old May 23, 2009 | 08:57 AM
pics or it didnt happen !
Old May 23, 2009 | 10:32 PM
kersh4w's Avatar
Hit & Run Magnet
ok.
so best to just leave it taped up.. or to poke a small hole in the tape... or to completely let it hang loose?
Old May 24, 2009 | 01:51 PM
Nemesis8's Avatar
Bigus Rotus
I disagree with Nem, here, because in the OEM orientation the three big hoses are only vents and not actual vacuum sources, nor are they seeking vacuum. They are actually controlled/metered vacuum "leaks". If you were to manifold them together the vacuum would render the jet-air and OMP nozzles useless as they need to see atmospheric pressure in order to work best. If you apply equal vacuum levels on both sides things may not work so swell.
My bad - I thought about that after I posted. Curious, under acceleration, will there not be a vacuum applied to those hoses?
Note to self: Never post in the Tech Garage unless you are absolutely correct.
Old May 24, 2009 | 02:03 PM
Nemesis8's Avatar
Bigus Rotus
I'm out in the garage looking at the setup again. That whole accordion tube is weird. I busted one of those cheap plastic elbows the other day, and improvised a temp until I got one from Jason for $5.65 each. Must be really nice plastic at those prices - LOL
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
Jb4ker96
Sep 27, 2015 10:06 PM
