Stock Renesis maxed out
Old May 18, 2009 | 09:31 AM
godchsr's Avatar
I'm a VW guy looking at buying an RX8. My google searches have turned up nothing. I see a lot of guys running the RX8 in the mid 300whp range but they only list modifications such as Forced Induction but no 'engine' modications.
On the stock motor what is its truest potential? Assuming of course that tuning has been done properly.
Old May 18, 2009 | 09:35 AM
expo1's Avatar
He's as bad as Can
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/all-turbo-talk-whats-highest-hp-na-rensis-153339/
Old May 18, 2009 | 09:40 AM
dozer's Avatar
on his 3rd rx8
o.O
Old May 18, 2009 | 10:07 AM
godchsr's Avatar
I read that whole thread just now and it seems to only answer the question "How much power are you able to extract from an NA Renesis?"
My question is:
"How much power am I able to extract (via any means... N2O, Turbo, etc...) before the stock motor can no longer mechanically function?"
Old May 18, 2009 | 10:18 AM
quazmosis's Avatar
Chode
I dont know if anyones truly answered that question yet.
Old May 18, 2009 | 10:23 AM
czar's Avatar
Almost boosted
lol i think people are still cautious, esmerial has a 400whp dyno, think they were claiming 500 with new apex seals but have never seen a dyno to back that.
godchsr's Avatar
Hmmm... So am I correct in assuming that the guy running turbos and low psi are using stock motors and producing 300 whp all on a stock Renesis?
If so that's a good power number. I'm not pipe dreaming that these are producing 500whp or anything crazy but I abolutely can not envision buying a 'sports' car that can't produce a measly 300whp on a stock 'block'.
Old May 18, 2009 | 10:26 AM
godchsr's Avatar
The Apex seals are a bit like Piston rings if I am to understand this correctly. That doesn't really sound like a big headache either.
Personally I would just want to stay away from having to have any machine work done on the motor. If a person can upgrade Apex seals and push over 400whp that is awesome!
Old May 18, 2009 | 10:30 AM
rx8thunder's Avatar
Being (new) single rocks!
Changing the apex seals is not cheap tho...
Old May 18, 2009 | 10:35 AM
dozer's Avatar
on his 3rd rx8
^yeah and you gotta be meticulous about it
Old May 18, 2009 | 10:44 AM
godchsr's Avatar
OK, so I can look at a long term plan of High power builds at least.
In the short term though: A T28 Turbo tuned properly on a stock Renesis should be able to produce reliable daily driven power in the 300whp range... correct?
Old May 18, 2009 | 10:59 AM
RK's Avatar
RK
It's Not Easy Being Green
The key there is tuned properly and it's harder to find an able rotary tuner than it sounds. Only real mod beyond the turbo and tuning is to go with either a high-flow cat or a catless midpipe and possibly upgraded ignition coils. Cats will die pretty quick once you go away from NA and coils begin getting blow outs when you start getting up around 300whp.
But 300whp is 'relatively' easy to achieve and stable with a good turbo or supercharger. It's a lot more expensive and a lot more work to get a Renesis up to there then it is to get a Vdub or just about any other piston engine.
Old May 18, 2009 | 11:18 AM
godchsr's Avatar
My very small 8 valve VW was putting down about 220whp, then I had a kill tune with nitrous that would put me around 280whp... That was a light fast car.
This is a part throttle run just hours after it's completetion. Due to unfortunate circumstances rust prevailed and took it's life rendering it unsafe for high speed racing (The drivers seat floor pan fell out and the drivers side strut tower scissored as well)
I am looking for a light weight replacement in the 10K range. The RX8 seems to fit that description. The VWs are nice looking but getting one to hook at 300whp is a task in itself.
Something RWD seems to fit the bill but driving a Z28 or another 300zxTT (Had 2 now) is just not my idea of fun anymore. A Supra would be nice but my budget is rendering that incapable.
I have a friend at works who trashes the RX8 like it's the worst thing the car world ever produced... He's a reliable source imo but I think all car in stages of infancy tend to get overlooked as a being unreliable when truthfully most people are just starting to figure out what they are capable of.
Old May 18, 2009 | 12:33 PM
expo1's Avatar
He's as bad as Can
I took that part of your first post to imply how much HP can you get from a non FI motor. I apologize for the link I provided. I think you might wish to follow the below thread. The creator of that thread has a good track record of getting power from RX-8's
https://www.rx8club.com/non-rotary-swaps-196/lsx-7-0-twin-turbo-engine-swap-170271/
Old May 18, 2009 | 01:30 PM
kersh4w's Avatar
Hit & Run Magnet
this is without touching the inside of the engine. there are 8.8lb rotors. down form 9.3lbs stock.
225whp n/a. i've seen dynos.
500whp turbo. claimed by chris. he has put a 414whp dyno down in the past. so i dont doubt him.
Old May 18, 2009 | 02:36 PM
WingleBeast's Avatar
HAVOC
MM has also yet to let us in on his max HP with satan hairdryer turbo, although im not sure it would be near 500 he seems to beat around the bush on it being over 400.
its not that the poential is not there, its the lack of RnD; our small community can only do so much in comparison to almost a century of piston experience. Not only that but asking your VW to get 300hp is only 150 hp per liter, wheras 300hp in the rotary is almost 240hp per liter
Old May 18, 2009 | 03:49 PM
Rocketman1976's Avatar
Tailgaters beware
There ar a few turbo kits on here that make 330-370 rwhp and there is also a safer easier Pettit Supercharger that many people run 330 rwhp with about 220 rw lbs torque and with the SC the car gets to retain the factory redline of 9000. The turbo kits tend to die off at 7800 rpms on most kits but make 240-265 lbs or torque with the 330-370 hp. From what I've seen the people with the SC can run high 12's with a set of slicks or drag radials, the turbos I don't know, it seems like no one really drag races the turbo cars by the lack of quarter mile info.
Look up pettit racing rx-8 in youtube and you will see many of them running 13.4-13.5's on radials doing dainty launches to prevent wheel hop from 3500 rpms where the car makes no power, with slicks they could launch at 6500 which is what it takes to propel these cars out of the hole.
Take one for a test drive and you'll fall in love, I've had many faster cars including a Turbo Supra but none were as addicting as this.
I don't know what my HP is rigtht now but I pulled on a 2000-2003 lexus GS400 the other day and they make 300 hp and 325lbs torque, it even surprised me.
Old May 18, 2009 | 04:00 PM
ChrisRX8PR's Avatar
13B-RE
Our turbo kit will give you power past 8200 if tuned properly. The 414whp run was breaking up at the top because we were with old sparkplugs and extremely rich....that 414 would have been way different if it hadn't been so rich/misfiery.
Best regards,
Chris
Old May 18, 2009 | 04:26 PM
Brettus's Avatar
Boosted Kiwi
10psi seems to be a comfortable boost pressure for the renesis
At that boost with a decent turbo you will make somewhere around 250lb/ft and 310whp
13-14 psi seems to be where people are stopping on stock internals (up till now anyway)
260lbft and 350whp
Old May 18, 2009 | 05:51 PM
shazy's Avatar
Damn that's pretty crazy... but I'm thinking 450whp is the limit. Any further, I would think you would have to do something drastic to attain any more power.
Old May 18, 2009 | 07:04 PM
godchsr's Avatar
Great info from everyone, THANKS!
I think this is the direction I will head. I'm not looking to blow everyone away at every stop light.... I'm looking for a quality handling vehicle that can get up and go.
I know from a stock perspective this car wouldn't be my first choice but then again how many people out there are capable of being 'inventive' when they all drive the same car with the same bolt on modifications! hahahahaha
Anyway... I hope this will be the beginning of a long relationship between me, the Rotary motor and the community surrounding it.
Old May 18, 2009 | 09:01 PM
Mawnee's Avatar
I divide by zero
I still have yet to see a reliable 400rwHP setup. The esmeril thread kinda went:
"414RWHP!!..rabble rabble rabble...rebuilding the engine...rabble rabble rabble... now shooting for 500RWHP"
Not saying it cant be done, but nobody is currently driving around 400RWHP turbo'ed Renesis with months of trouble free operation as such.
Old May 18, 2009 | 09:48 PM
godchsr's Avatar
$5700 is quite steep for a system that come with no management either...
Old May 18, 2009 | 09:55 PM
PSTNLSS's Avatar
The Former PSNTLSS
20B install... I say no more
Old May 18, 2009 | 09:57 PM
SayNoToPistons's Avatar
Wheels, not rims!!
I didn't read the whole thread. What was the reason for the rebuild? I heard that they are developing new seals and have put them in to handle more than 500rwhp but I don't remember reading anything about the engine being blown.
