Help/advice needed. Thanks guys
Old May 15, 2009 | 05:43 PM
wyldechild's Avatar
CA Help/advice needed. Thanks guys
Hey, so I know we get poor fuel economy; but, I believe I should be getting more than 170 miles average per tank. It's an 04 SS grand touring with 71k (bought with 67k). I drive hard and push it often but still 170 miles per tank is ridiculous. So I want to try to fix or replace a couple things in order to see a difference. I hear some people getting 300miles per tank and I want that or at least 230 average.
So far these are my ideas on what might fix my problem:
1. Replace plugs
2. replace wires
3. replace coils
5. clean MAF sensor
6. restart ECU
7. replace oem battery
Let me know if you other 8 owners have any other ideas or know exactly what I'm going through.
Old May 15, 2009 | 05:49 PM
YaXMaNGTO's Avatar
It's a Cavalier
How's the power?
Ever flood it? Check for clogged cats?
Old May 15, 2009 | 05:58 PM
wyldechild's Avatar
Power seems to be okay, it pulls pretty good. The car does flood though often when it comes to the short distance drives. Like turning it on and off all the time does not work at all. If I do that, like to get gas I usually have to sit there for a good 20minutes for the gas to evaporate. And, I haven't checked to see if my cat is is clogged
Old May 15, 2009 | 06:16 PM
04RX8man's Avatar
Rotary Powered Countryboy
well if u keep flooding it good change ur cat it gone....I changed my air filter and saw about 2mpg better(yeah it was bad) plug if you do plugs and coils should see some more...I know with my bad air filter i was gettin 170. IDK about 300 maybe all highway keeping in slow...
Old May 15, 2009 | 06:21 PM
636's Avatar
636
Rice Police
UM , you push it hard often and expect good gas mileage? Someones on crack lol. Even on a completely healthy engine , you wont get good gas mileage from doing that. Keep your revs low , and dont mash the gas pedal even on high load high gear , lotta **** depends on ur driving habits.
Edit , yeah i would change ur spark plugs , wires and coils. Clean ur maf , its not expensive to do lol. Did the previous owner change the plugs and stuff? if not then i would definately go ahead and do that , for maintenance sake. Might as well upgrade and get the Bhr ignition set or the esmeril while ur at it imo.
Old May 15, 2009 | 06:36 PM
wyldechild's Avatar
CA
Ok, I'll start checking out the cat and plugs tonight. I think the previous owner didn't change anything. I put a new air filter in so I don't think thats the problem. I'll check back after work to see if you guys left and more good advice. Thanks a lot.
Old May 15, 2009 | 06:38 PM
this is a GREAT start:
1. Replace plugs
2. replace wires
3. replace coils
5. clean MAF sensor
6. restart ECU
7. replace oem battery - ???? This one I don't get.
Old May 16, 2009 | 01:35 AM
wyldechild's Avatar
1. Replace plugs
2. replace wires
3. replace coils
5. clean MAF sensor
6. restart ECU
The car has the original mazda battery and I thought I should go get its charge checked out to see if its not up to par. is that a bad idea?
Old May 16, 2009 | 02:04 AM
8rocks's Avatar
Not a bad idea at all. Just doesn't tie to the other list you got going related to gas mileage.
Old May 16, 2009 | 02:21 AM
cjkim's Avatar
^noob
300 per tank is literally 100% highway. I've hit 320ish or so
Last fillup was 17 mpg @ 230ish miles.
That's a good list to start off with, but 170 isn't abnormal depending how you drive
Old May 16, 2009 | 03:13 AM
wyldechild's Avatar
I have only once experienced 225 miles on one tank during 90% highway. So what should I start with guys? check Cat and plugs first?
Old May 16, 2009 | 03:24 AM
8rocks's Avatar
Yes, Cat would be a great starting point.
Old May 16, 2009 | 09:39 AM
wyldechild's Avatar
ok, i'll get started this weekend. thanks again everyone
Old May 16, 2009 | 01:23 PM
exsequor's Avatar
wipe me down
I don't think you can conclude your MPG until you see what you get just on the freeway. It seems like my fuel goes like a leer-jet when Im doing city driving, but when I'm cruising at the same rpm at 75mph on the interstate I get at least 20mpg.
Old May 17, 2009 | 02:16 AM
wyldechild's Avatar
Ya; however, i still very much believe I'm getting less then what I could be getting.
Old May 17, 2009 | 02:35 AM
Ever Hernandez's Avatar
Rx8_4eVeR
Well, first change your driving habits, become a better driver. You're on the right track but don't forget to change your fluids often, capiche?
Old May 17, 2009 | 03:28 AM
Easy_E1's Avatar
50 to 75 miles per 1/4 tank is about average. Anything less is like what I get on the race track.
When was the air filter changed last? And any other routine maintenance?
Old May 18, 2009 | 02:05 PM
wyldechild's Avatar
Ya Easy, I'm getting less than 50-75 per 1/4 tank. The air filter was changed when I first got the car and all other maintenance is going to be done and checked out by me first thing I get a chance. Thanks a lot.
nowakm99
Oct 9, 2015 07:10 AM
Tsurugi
Sep 7, 2015 08:27 PM
