Trackday water temp.
Old May 12, 2009 | 04:20 AM
rotaryPilot's Avatar
Hi, I wonder what is the nominal water temp I can push my car to a track day without causing any damage.
Any track day drivers?
Old May 12, 2009 | 06:37 AM
MazdaManiac's Avatar
I, unfortunately, have a fair amount of experience with this, so I will give you my opinion - which will probably be roundly challenged by every Tom, Dick and Harry on this site.
There are 4 temperatures worth noting for the Renesis
Optimum power: About 185°F
Optimum efficiency : About 205°F
Maximum "safe": About 240°F
"Oh ****": 260°F
I know first hand about all of those ranges. The "oh ****" range is almost immediately followed by the coolant (and sometimes oil) leaving the motor in copious quantities through newly formed passageways between the housings and the irons.
Generally, if you are pushing the car and it starts advancing past the 230°F point, you should consider an immediate cool-down lap, though you won't destroy the motor at that temp.
Old May 12, 2009 | 06:51 AM
RK's Avatar
RK
It's Not Easy Being Green
What MM said. Plus this:
https://www.rx8club.com/showthread.p...=cooling+quest
Old May 12, 2009 | 06:56 AM
Fantastic post !! Thanks MazdaManiac.
Recently several RX-8 performed a track day having ambient temps at 80.6 F and we noticed a max limit of 221 F water temp. (about 6-7 laps track)
Old May 12, 2009 | 09:43 AM
04RX8man's Avatar
Rotary Powered Countryboy
good writeup....MM
05rx8mazda
Nov 28, 2015 09:42 AM
jDt!
Oct 2, 2015 04:04 PM
DG07
Sep 28, 2015 10:58 AM
