im freaking out man!
Old May 9, 2009 | 10:01 AM
skanrock87's Avatar
VA im freaking out man!
hey guys i just installed the agency power lightweight pulley for my ecentric shaft now my car is throwing a check engine light for misfire cylinder 1 any fix for that?
Old May 9, 2009 | 10:04 AM
04RX8man's Avatar
Rotary Powered Countryboy
did u knock a plug wire off
Old May 9, 2009 | 10:07 AM
myriadshalaks's Avatar
rot8ing
yeah, i don't see how the two are related unless you made an error when installing.
Old May 9, 2009 | 10:08 AM
skanrock87's Avatar
VA
naw didnt even touch them after the cel light came on i called mazda and they said it could be the plugs wires or packs so i replace all of them still got the code.
Old May 9, 2009 | 10:09 AM
rot8ing
hmm.
Old May 9, 2009 | 10:27 AM
Charles R. Hill's Avatar
Owner of BHR
You need to reset the e-shaft profile by doing the "20 brake pedal stomp" reset procedure.
Turn the key to on, but do not start.
Stomp brake pedal about twenty times(quickly) while watching the oil pressure needle until it sweeps all the way to the right and then back. If doesn't sweep, turn off, wait, and then start over.
Turn key off.
Start car as normal, if it's still on, then start over.
(Courtesy of "Mazsurfer".)
Old May 9, 2009 | 12:13 PM
Jon316G's Avatar
Grasshopper
+1
I had to do the same thing with my pulley install.
Old May 9, 2009 | 12:20 PM
G3tR3DDY2GR3DDY's Avatar
true story
Jesus Martinez
72
Jul 26, 2023 11:29 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
XianUnix
Sep 29, 2015 03:48 PM
tbiggybig
41
Jul 22, 2015 11:47 PM
