Going From "Park" to "Drive"
Old May 8, 2009 | 08:47 PM
ambitionz's Avatar
Exclamation Going From "Park" to "Drive"
Good evening, i have a automatic 2004 rx8
the mileage is 57,000
when i shift from park to drive
i feel a jerk and a lag when going
into drive...i was wondering if this can be
a transmission problem..
feedback would be appreciate, thanks
Old May 9, 2009 | 12:13 AM
Old Rotor's Avatar
Check the A/T fluid level and has it ever been changed(what color is it)? It could be motor mounts they have had a "TSB" out on them...here is a copy.
http://www.finishlineperformance.com...01-09-2062.pdf
Old May 9, 2009 | 10:52 AM
ambitionz's Avatar
yeah i changed the i A/T fluid the last saturday and its light brown, i am guessing its the motor mounts thanks a lot for your help.
Old May 9, 2009 | 12:51 PM
zoom44's Avatar
it was doing this before the change or only after? did you make sure to use only the CORRECT AT fluid?
Old May 9, 2009 | 11:35 PM
ambitionz's Avatar
it was doing it b4 the change and after
Old May 10, 2009 | 09:30 AM
zoom44's Avatar
Old Aug 5, 2009 | 01:51 PM
ambitionz's Avatar
o0o sorry i did a oil change i got mixed up
i ordered the AT fluid and i didn't change it
as yet, but as of now the AT fluid is black
Old Aug 5, 2009 | 03:49 PM
EDZRIDE's Avatar
2005 White GT
That's not good Sounds a rebuild is just about due.
Old Aug 5, 2009 | 05:57 PM
ambitionz's Avatar
yea when i put it in "D" the car just jerks
and in P and R its just normal ;/
Old Aug 6, 2009 | 12:34 PM
CyberPitz's Avatar
Huge hole is huge
Black AT fluid is BAAAAAAAAAAAAADDDD
Get that **** changed ASAP. The damage may already be done, though.
Transmission fluid should be red (or brownish if it's near the end of its useful life). Black indicates it has been seriously neglected and is failing to lubricate and cool the transmission properly thus damaging it.
Black ATF should be completely replaced, not just a drain and refill which leaves roughly half of the old fluid in the torque converter.
Avoid quickie shops for this kind of work, find a reputable transmission specialist to properly replace the fluid without causing more problems with detergents or power equipment not suited to the condition of the transmission.
The DIY alternative would be to drain and refill 4 or 5 times over the course of several weeks, gradually lowering the percentage of old fluid. This cannot be done all in a few days because it takes time for the old and new fluid to mix.
Old Aug 6, 2009 | 12:44 PM
Easy_E1's Avatar
The damage to the trans has more than likely been done. That's why the fluid is black.
Get the power flush from a dealer or reliable shop. You need to remove all the contaminated fluid.
I would ask the dealer if your drivetrain warranty is still good.
Old Aug 6, 2009 | 07:19 PM
ambitionz's Avatar
i bought the car used and it didn't come with any warranty
so i guess i am screwed
Old Aug 6, 2009 | 07:26 PM
Krazed_Rx8's Avatar
invasion08's Avatar
I would bring it somewhere the Auto Shop does a BG Transmission Service. http://www.bgfindashop.com/locator/index.php
Old Aug 6, 2009 | 09:24 PM
ambitionz's Avatar
thanks for your help
