Passenger Side Oil Cooler
Old May 4, 2009 | 08:16 AM
rx8shift's Avatar
Just wanted to see who else has done this on their AT rx8 and see what your impressions were before and after the install?
One thing I notice is that when the car is at running temperature the idle seems to be a bit smoother. I don't have temp. gauges in the car as of yet so I don't have any before and after temps. Does anyone on here know how much it brings the temp. down adding the second oil cooler? I have read 30 degrees F but do not know how accurate that is.
One other thing I would like to know is does anyone else notice that the oil at every change is dark? Not black but definitely a lot darker than I would expect considering I change my oil every 3k miles.
Cheers
Old May 4, 2009 | 08:56 AM
Red Devil's Avatar
We did this mod to a friend's RX-8. On track days his oil temps were about 40-45 degrees cooler after the install. Very worthwhile modification.
Old May 10, 2009 | 05:00 AM
DMRH's Avatar
Found a thread on this exact issue by some guy I know.............
>>>RX-8 auto "additional" oil cooler thread<<<
REgards
Old May 10, 2009 | 06:25 AM
Juice's Avatar
I made some poos
Cheers
During an oil change, you can't get all of the old oil out since it is stuck in the oil coolers. You'll likely only get a little more than half of it out with the 2 coolers you have now.
Its not a big deal, oil color is far from an indication that it has lost its lubricating properties.
Jesus Martinez
44
May 6, 2025 08:09 AM
ouimetnick
25
Sep 14, 2023 01:44 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
SayDfuse
Aug 3, 2015 10:41 PM
