CentraFuse TPMS Plugin
Old May 4, 2009 | 01:08 AM
rotarykillz's Avatar
Rotary Freak
Is anyone using a plugin for Centrafuse on their CarPC for the TPMS? If so, can you tell me which one? I looked on the Centrafuse forums and can only find one that utilizes aftermarket TPMS, but I was hoping that data would feed from the OBDII interface? Maybe it wont? Anyone know?
Old May 4, 2009 | 01:17 AM
Alexb's Avatar
desperately needs a drop
I am having so many issues with centrafuse right now.
Did you buy it or *borrow* it from bittorrent? ha
Old May 4, 2009 | 01:21 AM
Rotary Freak
It came with the CARPC when I bought it from alz0rz. How he got it, I won't ask :D
I just wonder if the 8 transmits TPMS via OBD II. If so, then a plug in is possible and probably already out there.
Old May 4, 2009 | 03:57 AM
krijpipudht's Avatar
Hi guys! My name is Tony.
From: San Francisco Bay Area 94542, USA. Earth. Solar System. Milky Way
I think Mazda has extra unit that deal with TPMS.
It is located under front center dash.
Old May 4, 2009 | 03:58 AM
Try new version.
Older version has a lot of trouble.
Old May 4, 2009 | 09:33 AM
tigerman81's Avatar
If I recall correctly you can't access the TPMS system from the OBDII interface. Kinda sucks but thats the way it is.
Old May 4, 2009 | 10:04 AM
Rotary Freak
I've been getting the feeling this was so after doing further research. There's another solution, but it involves replacing your TPMS with a USB based system. Probably more than I'd want to do at this point.
KWarner04's Avatar
Traveling Fool
From what I remember reading about alz0rz's setup (which you are now using), it's actually using "DashCommand" to read the ODBII codes. According to their website, here are all the generic codes they support (LINK).
They also support some "advanced/manufacture specific" codes for Ford (LINK), but not sure if these carry over to Mazda. I know at one point, they were considered the same thing, but my guess is they probably aren't for the 8.
Old May 4, 2009 | 10:06 AM
Rotary Freak
Thanks KW!! Appreciate the info
Old May 5, 2009 | 09:45 AM
Zeon's Avatar
I'm sure this is possible as the TPMS is just broadcasting on some set frequency to a monitor (315mhz seems to come to mind). Now, I don't know if TPMS is something like bluetooth that requires some sort of binding to a device or anything but I imagine it would be possible to intercept the message (assuming its not encoded as I mentioned) and interpret the information to display something on CentraFuse. This would require some extra hardware (I would assume) as well as some interesting interface, backend, and gui programming to get working... Probably possible though.
Old May 9, 2009 | 06:43 PM
Bighurk's Avatar
MeanRX8
what issues are you having with centrafuse? did you get it through BT?
Warrior777
Jun 24, 2019 04:47 PM
michaelsk8er
Nov 9, 2015 07:06 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
ShadowDragon78
Aug 21, 2015 03:29 PM
rx8cited
25
Feb 14, 2004 06:11 AM
