AC recharge
Old May 2, 2009 | 11:19 PM
Shijin-Kun's Avatar
Rotary Power!
AC recharge
This is a pretty noobish question: how do i recharge my ac. Summer is coming around and the ac isnt throwing freezing air anymore. Does anyone know how to do it?
Old May 2, 2009 | 11:40 PM
ken-x8's Avatar
If you buy a charging kit it will come with instructions.
Make sure you get one that has a pressure gauge, so you don't overcharge. Also, at least the first time you do this, get straight R-134. Not the kind that has oil mixed in, and definitely not the kind that has "special" additives.
Ken
Old May 2, 2009 | 11:42 PM
Easy_E1's Avatar
R134A ken-x8.
If you've never done this or don't even have a clue how to do it. Don't.
Or search the internet on how to recharge an A/C system.
Old May 3, 2009 | 12:59 AM
if u never work on ur car b4, I suggest u just suck it up and pay someone to do it.
Old May 3, 2009 | 01:04 AM
Shijin-Kun's Avatar
Rotary Power!
T_T .... ok
Old May 3, 2009 | 09:45 AM
04RX8man's Avatar
Rotary Powered Countryboy
I say u get it checked out and have some gauges put on it if it's not blowing cold at all then u might have a prob or leak.....you def don't want to overcharge so u better b careful....if u overcharge u could run into a problem of getting liquid through the condenser and into the compressor which is not a good thing.
Old May 3, 2009 | 12:05 PM
EDZRIDE's Avatar
2005 White GT
Not true but overcharging the system will give you higher then normal pressures and is very dangerous; doesn't cool worth a dam either.
Old May 3, 2009 | 02:33 PM
Georgia8er's Avatar
Get a professional to work on your A/C system, an independent shop isn't likely to charge you out the butt to inspect and fill, and you get cold air. The cold air is the most important part.
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
New Yorker
Jan 8, 2015 11:32 PM
jahfari
9
Jul 14, 2008 02:37 AM
ho1ming
Jun 23, 2008 02:06 PM
anotherrx8fan
Apr 6, 2008 09:59 AM
