HELP! Temperature Control Gone Mad
Old May 2, 2009 | 01:49 PM
ZoomZoomRx-8's Avatar
Hi everyone,
I was cleaning up the car today, it was switched off and I was cleaning the black shiny dash area around the stereo with a cloth (most of the buttons were getting pressed). Then I start the car, my AC is on (lights are all working) but its blowing super hot air. So I turn the temperature **** all the way to cold and just hold it down that way hard, AC starts blowing cold air again. The moment i let the **** go it starts to blow super hot air.
I have taken the stereo out (pulled it out a bit) to install the audiolink ipod adapter a couple of months ago.
Any idea what is causing this? any help is appreciated!
THanks!
Oh by the way it is a 2005 GT MT still under warranty.
Old May 2, 2009 | 02:23 PM
alnielsen's Avatar
Cold solder connections on the control board. There is a DIY repair posted on how to fix it. It will save you a lot of money.
Old May 2, 2009 | 02:25 PM
Thanks, but if the car is under warranty, I am hoping Mazda would take care of it.
Also, doesnt the soldering stop the heater from working?
Old May 2, 2009 | 02:30 PM
nuke0907's Avatar
Never Blend In
mazda should fix it for you.
why would soldering the circuit board keep the heater from working?
Old May 2, 2009 | 02:41 PM
alnielsen's Avatar
The control is a potentiometer that is soldered to a circuit board. A lot of the cars, including mine, have had this problem. They didn't use enough heat in making the solder connection and created a cold solder joint. After a while, this connection brakes and you can turn the **** and not get any response. I haven't fixed mine yet. I can wiggle the ****, make a connection and get it to work most of the time.
Old May 2, 2009 | 03:09 PM
Oh I see, thanks for the info.
So how do you get different levels of temperature to work if it works only when you "wiggle" it. Mine is fully hot air until i push all the way to the cold and hold it there. I felt its a connection issue too, but didn't think that was the soldering.
I will just take it to mazda and see. I have too many things wired in there (radar detector, audiolink and bluetooth) that I probably should take out before taking the car in...otherwise they might throw "warranty void" fit.
tommy26Germany
Sep 29, 2015 10:33 AM
pjwermuth
Sep 28, 2015 11:36 PM
Ian_D
Rotary Swaps
Sep 23, 2015 11:22 AM
