View Full Version : Damn foglights!
Genom
12-25-2003, 01:35 PM
OK. Have some time today to finally change thes puppy's out. Now I got the bottom plastic panel off and can reach the plug just fine. I can see it start to turn and it gets maybe 1/3 of the way and STOPs. I mean STOPS. I just spent 45 minutes trying to twist them off and I cant get them to budge either way more than a few milimeters.
Both sides do the same thing. ic an see the 3 flanges in front that need to move to get it out but they will not budge beyond a very small radius. Is there something I am missing?
Thanks.
kristopher_d
12-26-2003, 12:27 PM
You probably need to press them in, then turn. Haven't looked at mine, but that's usually the problem when a bulb wont budge.
Omicron
12-26-2003, 02:07 PM
Yeah, that's what I was going to suggest.
syntrix
12-27-2003, 09:19 PM
Yeah, push in a bit.
Also they will only turn one way and come out. As they get closer to the point of release, they get harder to turn.
Genom
12-28-2003, 07:37 AM
I'll give it another go and try pushing a bit. I thought I tried that as well, but maybe I didnt push hard enough.
T666APH
12-28-2003, 02:53 PM
If you look in through the lens you can see the key-way, easiest way in up through the lower plastic couple off screws easy!
