I have no heat help me please!!
Old May 1, 2009 | 03:32 PM
xO MazdaRx8 Ox's Avatar
D R ii F T
i have had no heat for quite a bit and then a buddy told me to try replacing the thermostat and i just did it today. However, I still for some reason will produce no heat. Also, whenever I use the A/C, my power steering just stops working the second I shut the car off. Any suggestions are appreciated
Thanks,
Cory
Old May 1, 2009 | 03:36 PM
ambitious8's Avatar
From hungry to greedy.
The solder joints on our cars seem to crack and disconnect. You can either order a new unit or solder it together yourself.
I did the DIY and it took me about 2 hours to do it fully, along with the ipod hookup. So could've been a little less time. It is a pretty simple fix. Ill try and find the DIY and repost it here. Hope this helps. Good luck.
Here ya go: https://www.rx8club.com/showthread.p...highlight=heat
Old May 1, 2009 | 03:43 PM
D R ii F T
thanks alot i will read this through and let you know if it helped at all thnx again
cliffkemp
Dec 24, 2024 10:48 AM
05rx8mazda
Nov 28, 2015 09:42 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Vedivan1
Sep 20, 2015 04:39 PM
