How much oil you need when perform transmission flush?
Old May 1, 2009 | 09:25 AM
Luckycat's Avatar
Hello,
I plan on doing a transmission flush on my car and replace the oil with synthetic transmission oil (Amsoil). At 22K mile I only drained the old oil and replace with 4 quad of Amsoil syn oil. Now at 41K miles I want to do a complete flush and replace all oil. How many quad do I need?
Thanks.
Old May 1, 2009 | 09:28 AM
dozer's Avatar
on his 3rd rx8
manual transmission only takes about 2 quarts...and i highly recommend you use redline instead
Old May 1, 2009 | 09:37 AM
dillsrotary's Avatar
jersey fresh
transmission i believe is 1.8 liters
Old May 1, 2009 | 09:41 AM
1.8 quarts. not L
Anyway, to op. find the information on your own. Its every freaking where. god.
Old May 1, 2009 | 09:57 AM
You called nycpgs?
I'm very busy in a discussion with rotorygod up here.
Old May 1, 2009 | 11:00 AM
risky business's Avatar
IRC Founder
1.8
and if you have a MT and not an AT, its a drain and fill, not a flush
go to GM and get synchromesh + Friction Modified. that **** is liquid gold (its $15 a quart but worth it)
Old May 1, 2009 | 11:02 AM
Luckycat's Avatar
Thanks guy. I did some search and found good info. My car is manual and I forgot how much I put in the oil last time. How often do your guy check the transmission fluid level?
Old May 1, 2009 | 11:31 AM
ndhoffma's Avatar
I never do... just change it out when it needs it
You wont be loosing/using fluid unless you have a leak or some major issue like that
Old May 1, 2009 | 03:57 PM
Originally Posted by Razz1
You called nycpgs?
Attached Thumbnails How much oil you need when perform transmission flush?-omnipotent-makes-sense.jpg
Old May 1, 2009 | 09:21 PM
kersh4w's Avatar
Hit & Run Magnet
Old May 1, 2009 | 10:46 PM
-_-
Warrior777
Jun 24, 2019 04:47 PM
Dokuji
Nov 1, 2016 02:51 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
MolecularConcept
Aug 5, 2015 04:43 PM
