Rough Shifting in 2nd and Reverse
Old Apr 27, 2009 | 05:30 PM
XxChrisxX's Avatar
Desert Cruiser
Its not awful, but shifting into 2nd and reverse isnt quite as smooth as the other gears. I just bought this 06 Shinka and it only has 11k miles on it. Previous driver was pretty easy on it too.
Old Apr 27, 2009 | 06:25 PM
DeViLbOi's Avatar
The devil made me do it
What RPM are you shifting at?
Old Apr 27, 2009 | 06:40 PM
XxChrisxX's Avatar
Desert Cruiser
Doesn't seem to make a difference. Reverse is at idle. 2nd anywhere from near idle to 6-7k,
Old Apr 27, 2009 | 06:59 PM
DeViLbOi's Avatar
Pausing in Neutral help for second?
Old Apr 27, 2009 | 07:16 PM
warren(silver-roxy-8)'s Avatar
no sleep til it spools
i have that 2nd gear problem too, but that's only at 20+ mph. don't shift above 20+ mph tho, i heard that has a negative effect ur tranny
Old Apr 27, 2009 | 07:27 PM
mscamp02's Avatar
Blue Bullet?
I have a similar problem with 4th...if you shift at high RPM without a pause in neutral it rejects it.
Does it help if you pause in neutral and let your engine calm down
Old Apr 27, 2009 | 07:37 PM
DeViLbOi's Avatar
I shift into second at 40 all the time...as long as you rpm match and don't just jam it into gear you're fine.
Old Apr 27, 2009 | 08:26 PM
myriadshalaks's Avatar
rot8ing
yeah, try holding down the accelerator a little longer as you engage the clutch. that is, don't let off the gas before you clutch, let off the gas just after you clutch.
if that doesn't work, there's always the double clutch.
reverse is just hard. you have to push down. there's a pin in there to prevent you from jamming it in reverse instead of 4th or 6th.
see the axial flow short shifter diy for a picture of a similar pin.
Old Apr 27, 2009 | 08:54 PM
jesus......are you red lining or damn near?
Old Apr 28, 2009 | 06:07 AM
DeViLbOi's Avatar
Uhmmm...yea...Why aren't you?
Old Apr 28, 2009 | 06:27 AM
mscamp02's Avatar
Blue Bullet?
thats not really going to hurt the engine....its kinda made for it
Old Apr 28, 2009 | 06:41 AM
DeViLbOi's Avatar
If done improperly it could damage the tranny...I'll give you that. But otherwise...Red Line a Day keeps Montrose Mazda away!
Old Apr 29, 2009 | 07:08 PM
i understand that, but i'm talkin about gas consumption man! lol
Old Apr 29, 2009 | 07:14 PM
blamerobb's Avatar
gas on an 8. Get rid of it and get a civic if u want good gas mileage. And I can't downshift into fifth unless I rev match. It's like trying to shift through a brick wall. All Grundy and sounds awful
Old Apr 29, 2009 | 07:22 PM
you prove a veeery good point
Old Apr 29, 2009 | 07:27 PM
haha never said i wasn't
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
