CAMBER HELP!!-(repost in order to get more feedback)
Old Apr 22, 2009 | 10:32 PM
MyNam3IsM33TBALL's Avatar
IL CAMBER HELP!!-(repost in order to get more feedback)
SO heres the dilemna... Tires are wearin' way too quickly on the inside so I went to get an alignment only to find that i've got about -3.20 camber in the rear so they said i wouldn't be able to do anything for me.
I've got sprint-tech springs on stock shocks with about a 2" drop...aftermarket rims-- 18" 8.5 with 40 offset... 245-40-18 Dunlop Direzza's
Question 1- How the hell is my camber so bad compared to others with the same drop that are only seeing a -2.00 camber.
Question 2- What is the CHEAPEST way to get less negative camber...cuz i do NOT feel like spending $700 on adjustable control arms. Would full coilovers help? (mind you i'd still keep it at an agressive drop..and i the money would be more worth it then the control arms). Would spacers affect the camber at all?
I'm in no way or form proficient with suspension so before anyone says anything, i searched and found little bits and pieces...but nothing tailored to my exact dilemna so PLEASE... constructive input appreciated
Old Apr 22, 2009 | 10:35 PM
dozer's Avatar
on his 3rd rx8
camber kit...and i honestly do not know who sells them...mine was almost just as bad, they fixed my camber a lil and sed that was all they could do, i finally got new rims and it seemed to help it out more...
Old Apr 23, 2009 | 10:26 AM
costello's Avatar
You probably can get less negative camber. The shop probably saw that you were lowered and just said "hey we can't get it any better" because they can't get it within the specs of a stock car. Take a picture of the camber adjustment bolts and post them and we can tell you if you can reduce the camber. If you can get it down to -2.5 or less and set the toe to zero then you should be ok. The important number is to get the toe angle to zero.
Digitz0070
55
Jul 25, 2017 08:40 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
duworm
Oct 1, 2015 04:57 PM
FubarI33t
Sep 28, 2015 08:45 PM
titaneum_grey
Sep 16, 2015 11:51 PM
