Enkei Rpf1 tire size
Old Apr 21, 2009 | 04:27 PM
TRU5hot's Avatar
Hey im looking into putting Azenis Rt-615 tires on my Rpf1's what is the best size?
Old Apr 21, 2009 | 04:28 PM
cjkim's Avatar
^noob
best is relative
but can't give any answers without rim size at the least
Old Apr 21, 2009 | 04:29 PM
Spinning Sushi's Avatar
I <3 Sushi
125x200x12
Old Apr 21, 2009 | 04:30 PM
cjkim's Avatar
^noob
Originally Posted by Renesis SE3P
125x200x12
trying to picture that. lol
Old Apr 21, 2009 | 04:35 PM
TRU5hot's Avatar
Lol wow sry there 18x9.5
Old Apr 21, 2009 | 05:01 PM
TopGear8's Avatar
mkuhnracing.com
^I have 275/35/18's on mine. You will be fine with anywhere from 245-275.
Old Apr 21, 2009 | 05:02 PM
I8U's Avatar
I8U
First read up on a few of the threads listed below in the similar threads box.
Old May 15, 2009 | 02:46 PM
TRU5hot's Avatar
Okay so I still can't decide what size. Does the 275/35/18 fit fine on the front of the car? Any personal experiance would be of great help. Thank you
Old May 15, 2009 | 02:56 PM
TopGear8's Avatar
mkuhnracing.com
^YES I have the same wheel and 275/35/18 all around and I am lowered 2" on Coilovers and YES IT FITS!
Old May 15, 2009 | 02:57 PM
J8635621's Avatar
Pew Pew Pew
Did you seriously not read what topgear8 told you? He runs 275/35 on his, meaning he has the same setup you are asking about. Also, that setup is on about eleventy billion rx8s so it will work no problem. edit: lol I'm too slow
Old May 15, 2009 | 03:09 PM
RK's Avatar
RK
It's Not Easy Being Green
It's more than that. Not to mention it's listed in the What Fits thread a bazillion time, the Enkei Owners thread 72 gajillion times, and offered as the preferred size in all quadrillion shops that sell the RPF1s to RX8 owners.
Other than that you have to get pretty specific on your search...
lol
Old May 15, 2009 | 04:21 PM
Ever Hernandez's Avatar
Rx8_4eVeR
Hey, if you're stock my feeling is 275 may be a bit too much tire on all four corners.
Old May 15, 2009 | 05:33 PM
TRU5hot's Avatar
And if my car is N/A the bigger wheels wont be a problem? Is my car "Not fast enough" for bigger?
Old May 15, 2009 | 05:40 PM
Rx8_4eVeR
Well, let me put it this way. When I was running 245's on stock wheels MY car felt normal I guess. When I switched to the GT-V's (19's) I could actually tell the difference and it was significant.
Old May 15, 2009 | 05:42 PM
Roariee's Avatar
It was this big! No lie!
I run the same size tire 275 on the RPF1's and you get massive grip at the cost of weight.
But since the wheel is so light, it balances out.
Old May 15, 2009 | 06:07 PM
TRU5hot's Avatar
And what about BF Goodrich g-Force T/A KDW any experiences with these tires?
Old May 15, 2009 | 06:08 PM
Roariee's Avatar
That's the tire I switched to...great all weather traction...hard tire lasts a long time...
Old May 15, 2009 | 10:44 PM
TRU5hot's Avatar
Nice griping good for track use too?
Old May 15, 2009 | 10:57 PM
TopGear8's Avatar
mkuhnracing.com
^If you want a nice gripping tire get the new Kumho Ecsta XS.
Old May 16, 2009 | 07:26 AM
dmp's Avatar
dmp
RX8 and a Truk....
Unless he goes FI there aren't many mods which would increase his car's HP beyond a dozen, maybe. Possible you felt the gearing change effect?
Old May 16, 2009 | 10:31 AM
Rx8_4eVeR
Yeah, I never assumed I got mad HP from switching to different lighter set of wheels and that's not what I was implying, sorry. I guess that effect you speak of, would be the same effect you get when switching to a lightweight flywheel. You're not really making any more HP, you're just using it more efficiently, right?
Well, OP let me say this. Consider the fact that if you're using your car as a daily driver you may not like the jittery ride that comes with wide hard tires, especially if you're on coilovers. Not to mention the noise once you put a few miles on. I'm not saying don't do it, just giving my opinion.
I' considering a different set of wheels in the future, same size, 18x9.5, but I'm leaning toward a 255/35.
Old May 16, 2009 | 11:58 AM
TRU5hot's Avatar
I found those tires installed and everything for $900 so that's why im pushing those tires. Im just checking to see if it would be dumb if i bought them.
Old May 18, 2009 | 04:19 AM
Roariee's Avatar
yes and no...they are a nice hard tire so they take a while to warm up...once they are, they are fairly predictable as in a "greasy" feel. It's not "loose" as in you feel like they liquefied, but a greasy feeling line...as opposed to a higher end summer / track tire which is much "tighter". But for a daily driver tire, its great. Tracking, I would say a medium. Not great, but does the job and has minor trade offs.
Best bang for the buck in DD applications with light track time.
I think long term track purposes, you should invest into a 17" wheel. I intend to get the RPF1's in 17 later on. R-Compounds and generally most other "track tires" are SIGNIFICANTLY cheaper in the 17 size.
Also the size difference alters the car's final drive and give you a small acceleration boost.
The type of tire also affects the weight. A 245/35 of brand XYZ might weigh twice the brand of ZYX, despite having the same dimensions.
A heavier tire is going to require ALOT more power to move and the impact can usually be felt.
The less weight you have to get rotating the more responsive the car will feel.
That's a good deal if they have life left.
One other "downside" of this combination. Due to the footprint, you pick up ALOT of road noise and feedback. The car WILL track grooves and ripples in the road. Be prepared to have grip, at the cost of always having to use both hands too actually have to "drive".
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
CMRine04
Sep 17, 2015 10:04 AM
fireishot34
Sep 5, 2015 06:45 PM
