unstable idle, where's the likely problem?
Old Apr 20, 2009 | 11:35 PM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
My car is a 2004 AT. In recent months I had suffered from intermittent unstable idle. It would raise to 1200-1500 rpm in N gear when car completed stopped. The dealer changed the throttle body, airflow senser, checked the vaccum, spark plug but the problem remained. The high idle rpm can be improved if shift the gear to D but I noticed it still higher than ususal (800-950). Is there anyone help?
Old Apr 20, 2009 | 11:44 PM
shaunv74's Avatar
Power!!
You mention they changed the spark plugs. Have they changed the ignition coils? If not that is the next most likely problem. They only last 30-40K miles.
Old Apr 20, 2009 | 11:58 PM
zaku's Avatar
I forgot it. They did change my mazsport coil back to factory set, but the condition was not changed
Old Apr 21, 2009 | 03:47 PM
I hope you still have the Mazsport coils.
Sounds like you have an auto.
We have had some problems with a neutral switch in the MT's and hunting idle.
Yours is just idling high right?
Old Apr 21, 2009 | 04:13 PM
how's your MAF sensor?
Old Apr 21, 2009 | 04:37 PM
zoom44's Avatar
they changed your throttle body for a hunting idle? wtf? the spec for idle is 750-850 so if your idle sits at 800 most of the time with an occasional run to 950 id say its probably just a dirty maf.
dont bother shifting to N at a stop just leave it in D
Old Apr 21, 2009 | 04:52 PM
Easy_E1's Avatar
MAF, MAF wire harness connection. Dirty air filter. Could be a vacuum leak somewhere too.
Old Apr 22, 2009 | 09:14 AM
zaku's Avatar
After the change of the throttle body, they change the MAF sensor (50000km), but it did not work. After one week the condtion reappeared
Old Apr 22, 2009 | 09:19 AM
zaku's Avatar
Mazsport coil works well for me still
The problem occurred at randaom timing, Some times all day long but ceased when I reached dealer shop
It also threw no CEL
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Sep 11, 2016 02:51 PM
Randolph Alvarez
May 30, 2016 01:08 AM
DVerdeyen
Sep 13, 2015 11:19 AM
iwannarun
Sep 6, 2015 01:37 PM
